Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2004
    Posts
    335
    Default Cruising Greece (Ionian and Aegean)
    OK i am starting to research a trip to Greece this summer.
    I am skippering a 25m motor yacht, my owner would like to go to the Ionian and Aegean via Corinth canal
    Does anyone have any recommends, must see places, areas to avoid etc etc.
    Leaving Spain beginning of June and expect to arrive mid June. Staying fo 3 weeks.
    All info welcome
  2. #2
    Join Date
    Nov 2007
    Posts
    15,307
    Default
    You are going to be very limited in the places you can visit - at least in the Ionian as there are virtually no marinas and most of the harbours are too small to berth something that size. You are OK in Corfu and Levkas - but not sure you will get down the Levkas canal depending on your draft. There are anchorages on many of the islands for lunch stops. Should be OK in Patras and you can transit the Corinth Canal. Better facilities around Athens, but marina space can be difficult.
    Suggest you buy Rod Heikells Greek Waters Pilot. Sailing boat orientated as this is the choice of most cruising in the area, but it has enough information for you to identify the potential spots.
  3. #3
    jimbaerselman's Avatar
    jimbaerselman is offline Registered User
    Join Date
    Apr 2006
    Posts
    3,350
    Default
    Quote Originally Posted by Lozzer View Post
    l
    That's what my web site is designed to do.
    Yours is a big boat though, and my comments all assume <24m
    JimB
    http://jimbsail.info helps Skippers plan Europe Cruises
  4. #4
    Mad Pad is offline Registered User
    Join Date
    Jun 2011
    Posts
    163
    Default
    The Agean tends to get very windy in the summer.Being a motorboat you may be more comfortable staying out of there.
    You could do the Ionian then go north to Albania,Montenegro and Croatia.
    DYOR
  5. #5
    Join Date
    Sep 2004
    Posts
    335
    Default
    Thanks Jimb. Will take a look
    I am assuming lots of anchoring in bays keeping an eye on the weather. Especially he Meltimi.
    Mad pad. Not my choice I'm afraid. If the boss wants to go I have to go!!! Of course I will dmor however there are experienced people here and tapping into that resource is all part of my research.
  6. #6
    Join Date
    Jan 2007
    Posts
    925
    Default
    Might be well worth posting your request for information on the liveaboard forum, as there are a number of experienced liveaboards out in Greece with a wealth of knowledge.
  7. #7
    Join Date
    Dec 2011
    Posts
    166
    Default
    IF you are also looking for pilot guides,I find sailingbooks.co.uk with their summaries of most what's available a good place to window shop. Their service is actually first-rate as well.
    www.sailingbooks.co.uk/trolleyed/27/48/index.htm
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
