Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    SimonA is offline Registered User
    Join Date
    Nov 2004
    Posts
    1,396
    Default
    Try some cheap supermarket washing powder mixed with hot water.
  2. #12
    Join Date
    May 2001
    Posts
    11,609
    Default
    Quote Originally Posted by Tugw View Post
    Is that the trade name?
    Probably more widely known as "Simple Solution", I have also used it with success - also removes red wine stains from fabric.
    I have also used Daz in near boiling water in bilges with some success too.
    Warning - Internet forums may contain nuts
  3. #13
    Join Date
    Mar 2007
    Posts
    1,650
    Default
    Stockholm tar ... make her smell like a proper boat!
  4. #14
    SteveTibbetts is offline Registered User
    Join Date
    May 2008
    Posts
    140
    Default
    A hopefully minor drift - what to do if there's only minimal access to the bilge? Mine have only a couple of small holes to the side lockers, one to the engine bilge and about half inch around a compression/table support post. I know there's a gunky oily mess down there about an inch deep I reckon but can't actually get to it. What to do? Make an access hole in the saloon floor?
  5. #15
    affinite's Avatar
    affinite is offline Registered User
    Join Date
    Feb 2005
    Posts
    694
    Default
    As has already been said, do make sure that you check for the source. Bilges on my new boat were also "stinking". I found that a concealed anti-siphon loop vent had failed and was spraying *rappy water up behind the heads and down into the bilge
    Have now sorted the leak and now off to swindlery for some bilgex.
  6. #16
    Join Date
    Jan 2003
    Posts
    4,464
    Default
    Quote Originally Posted by davidej View Post
    I think bleach is the first stop (as well as the cheapest). A good swill round will kill the bacteria (often the cause of the smell) and makes the bilges look a whole lot better.
    If the smell persists- try one of the expensive cures.
    I've also used bleach to good effect.
  7. #17
    Billjratt's Avatar
    Billjratt is offline Registered User
    Join Date
    Sep 2004
    Posts
    2,388
    Default
    Stop papering over the cracks!
    Where's the "stink" coming from?
    Find and fix....... You don't say what the boat is, but unless it's been designed in, (the smell I mean) in which case the users association will have some workaround to circumvent, you have a FAULT...
    - water (maybe contaminated by 'heads liquids' or from the galley) is getting to somewhere it can fester and develop. You have to prevent it from getting there, rather then mixing something probably equally toxic, but less odorous in with it and then having to pump out.
    If it's "Condensation"as a lot of new boat owners seem to prefer.. you need more airflow - again a design problem.
    Left hand down a bit.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
