Results 1 to 6 of 6
  1. #1
    Join Date
    Feb 2007
    Posts
    270
    Default Removing Water Marks From Teak Cockpit
    We fitted Teak decking to the cockpit of our Sealine 420 last year and it still looks great except where the hood has been leaking leaving water marks in several areas. Any ideas how to get rid of them.
    Geoff
    You dont need eyes to see you need vision.
  2. #2
    Join Date
    May 2001
    Posts
    9,615
    Default
    Wessex 2part cleaner, job done!
  3. #3
    rafiki_ is offline Registered User
    Join Date
    Jan 2009
    Posts
    4,956
    Default
    Oxalic acid will also bring any dirt or stains out. The poor mans way to clean the teak, and many other things too.
    I have this job to do on Rafiki either this or next weekend.
  4. #4
    Join Date
    May 2001
    Posts
    9,615
    Default
    Quote Originally Posted by rafiki_ View Post
    Yes I also use oxalic acid, particularly if the teak is very dirty, but nothing does the job as well as Wessex (or other companies equivalent).
  5. #5
    Default
    I wouldn't use oxalic acid on dirty teak, it'll end up patchy. Oxalic acid is part 2 of the Wessex system (and every other 2 part teak treatment), and you use it to restore the colour after you've cleaned it with part 1.
  6. #6
    Join Date
    Feb 2007
    Posts
    270
    Default
    Thanks for the info guys, I have the Wessex gear but as the decking is still as new was reluctant to use it as it is only a few areas of water staining.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
