Results 81 to 88 of 88
Thread: Med mooring - springs
30-04-12, 10:00 #81
30-04-12, 10:15 #82
Registered User
- Join Date
- Jan 2007
- Posts
- 789
30-04-12, 11:08 #83
30-04-12, 11:17 #84
30-04-12, 12:06 #85
Well I don't use anything, because on my mooring the rope joins the chain about 3 feet below the point where I cleat off, so I can guess it closely enough, but if you want something permanent why don't you get some red whipping twine and whip a length of about 20mm?
http://www.force4.co.uk/3798/Liros-W...mm---Red-.html
30-04-12, 13:24 #86
30-04-12, 13:36 #87
Are your bow lines different in some other respect?
I'm asking because aside from the length, I find it convenient to have an obvious way to differentiate between port and stbd lines.
In fact, sometimes it happens that the dock hand gives you the wrong one.
Though actually that is more of a problem if you have fin stabs, because by crossing the line under the hull you risk to pinch it between the fin and the hull.
Which makes for an interesting situation, the next time you're leaving your berth...
30-04-12, 15:22 #88
The lazy line of one is attached to the mooring ring on one side of the boat, the other on the other side, so no chance of getting them mixed up. The bigger issue is to be given the neighbours port side line instead of your stbd side, and vice versa, but the lazy lines are (by chance) a different colour so we always know.
Bookmarks
