Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 65
  1. #21
    Woodlouse's Avatar
    Woodlouse is offline Registered User
    Join Date
    Jan 2006
    Posts
    4,402
    Default
    Quote Originally Posted by BobPrell View Post
    Everybody is in favour of efficiency. For some reason bermudan fans get away with claiming efficiency without saying what resource they are efficient with, and what they trade off for that.
    So the gunter is efficient with space. It trades off pointing ability.
    By efficient I was talking about aerodynamic drag, pointing ability, top hamper, ease of handling and simplicity. The bermudan rig wins on all points here. But please don't mistake me for a fan. I'm personally an old gaffer, but it doesn't stop me from recognising the benefits of different rigs.
    Yes, the gunter is efficient with space, and if I was to choose between the two I would probably go for it, especially on a boat with a tabernacle that might require regular trailing.
  2. #22
    Join Date
    Dec 2002
    Posts
    9,397
    Default
    Quote Originally Posted by dylanwinter View Post
    here are two pictures of the same boat with different rigs
    which would be better for sailing around the UK?
    http://www.hlmoa.flyer.co.uk/images/mn.jpeg
    http://www.hlmoa.org.uk/gallery/14George_Gunn_1.jpg
    and would you be interested in an article in a well known yachting magazine about comparing the two rigs?
    yours
    Just curious of Buckingham
    My frst boat was gunter-rigged. I found it a bit of a pain and would have converted it to Bermudan had I kept it.
  3. #23
    Join Date
    Jun 2004
    Posts
    4,298
    Default
    Major advantage of the Bermudan rig will be when sailing to windward. How much sailing to windward are you likely to be doing?
    Is to be the Limax maximus?
  4. #24
    BobPrell is offline Registered User
    Join Date
    Sep 2004
    Posts
    954
    Default
    Quote Originally Posted by Woodlouse View Post
    Excellent, I have found someone like-minded. I was rather worried that I might have given offense.
    I am a bit of a junk rig fan myself, it is efficient with the labour required to sail.
    The bermuda rig is efficient with most of the things you have listed, but it has costs. One is the work required to sail. I hope you have seen the "Commands required to tack" thread. A junk sailor posted "I can't understand what all the debate is about, when I want to tack I just push the tiller over".
    Dylan, my mind's eye keeps seeing your boats (slug and the minstrel's) with junk rig.
    A l'eau. C'est l'heure.
  5. #25
    Join Date
    Jul 2005
    Posts
    6,475
    Default
    Hmmm.
    Perhaps a question should be: How well does a Minstrel sail to windward at all AT SEA without motor assist? Thats quite a bluff bow and high topsides and canoe stern and and .. very pretty.
    I believe the Bermudan set up has/had tan sails too usually, unlike that pic..
    Whilst I don't want to rain on your parade, i had a junk rig Corribee with bilge keels that i took places that others simply do not venture ( but not on your route) and it would tack in its own length and retain steerage way on a tide breeze drifting thru saltflats and marshes...You will surley be doing loads more of that than coastal pure sailing to windward?
    Gaffers 'know' that a low aspect rig is often the best for drive..
    So basically I would advocate the lower, gunter rig, even for powering to windward with that hull, it is pretty, unique, characterful, wont do your adventure or public image/ thread count/website hits any harm at all, easy peasy to up/down and stow.
    As said, above all I would be looking at the quality or cost of a really decent motor with the ones for sale..
  6. #26
    Lakesailor's Avatar
    Lakesailor is offline Registered User
    Join Date
    Feb 2005
    Posts
    13,296
    Default
    Quote Originally Posted by interloper View Post
    A Westerly Centaur is only available with a Bermudan rig.
    Fascinating. Not sure how it helps in this thread.
  7. #27
    Fantasie 19's Avatar
    Fantasie 19 is offline Registered User
    Join Date
    Mar 2009
    Posts
    1,848
    Default
    yours
    Sheer unadulterated boat porn....
    http://www.western-horizon.co.uk/arc...hp?boat_id=25#
    ....I'd bite your arm off for that boat with either rig, but would prefer bermudan if given a choice.....
    "Reality,' sa Molesworth 2, 'is so unspeakably sordid it make me shudder."
  8. #28
    wklein's Avatar
    wklein is offline Registered User
    Join Date
    Sep 2010
    Posts
    451
    Default
    How would a gunter motorsail? If your a fan of motoring when conditions are ticky surely a bladed bermudian would be better than a gunter?
    I have no real experience of gunters apart from two dinghy's i had rigged that way.
    If your sailing around Britain on anything like a deadline there will be a fair amount of windward work and unless you are planning to drop mast regularly I would go bermudan every time.
    Yes, to dance beneath the diamond sky with one hand waving free
  9. #29
    prv is offline Registered User
    Join Date
    Nov 2009
    Posts
    13,397
    Default
    Quote Originally Posted by wklein View Post
  10. #30
    wklein's Avatar
    Join Date
    Sep 2010
    Posts
    451
    Default
    I don't suppose anyone is interested but here is the gunter i used to own:
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
