Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    snooks's Avatar
    snooks is offline Registered User
    Join Date
    Jun 2001
    Posts
    4,196
    Default Anyone seen the shackles for my sails?
    I put them somewhere safe in October, now it's time to bend the sails on and I can't find them
    Blog of a yachting photographer http://grahamsnook.com/news
  2. #2
    Join Date
    Oct 2001
    Posts
    273
    Default
    Hmm... I left the mainsail tack shackle attached to the gooseneck fitting, the clew one attached to the outhaul runner in the boom, and I couldn't get the one that attached to the halyard off If I wanted to. Likewise for the genoa. So that's where I'd look for them.
  3. #3
    Join Date
    Feb 2007
    Posts
    6,280
    Default
    Whoever has pinched this lot - could they return the Clevis pin from my boom strut?
    Far away is near at hand in images of elsewhere
  4. #4
    prv is online now Registered User
    Join Date
    Nov 2009
    Posts
    13,954
    Default
    I always leave rig shackles attached to one side or the other of what they used to hold together.
    Not that that's much help to you now
  5. #5
    Woodlouse's Avatar
    Woodlouse is online now Registered User
    Join Date
    Jan 2006
    Posts
    4,620
    Default
    Look in the chart table. Things like that always migrate towards the chart table.
  6. #6
    Join Date
    Jul 2005
    Posts
    6,699
    Default
    The fun is reuniting all the other 'losts and founds' whilst searching for, er, I forget now, what was I looking for again?
  7. #7
    Puggy's Avatar
    Puggy is offline Registered User
    Join Date
    May 2007
    Posts
    190
    Default
    Mine are often found precariously perched by the grab rail on the deck where I put them down when taking off the sails at the end of last season....
  8. #8
    Bosun Higgs's Avatar
    Bosun Higgs is online now Registered User
    Location : they think they might have seen me, but have they?
    Join Date
    Nov 2009
    Posts
    10,729
    Default
    A minor issue Snooks. Put some new ones on and you will find the old ones straight away.
    I managed to lose / forget the link at the top of my forestay, only discovered when the backstay was too short and the mast leaned forwards . . Then of course I found it the next day so had a pleasant hour or so up the mast with no forestay connected trying to fit the link. With mobos going past making wash - you scream at them to slow down and they look around but never upwards.
    The inside of my thighs is still sore after clinging to the mast like a monkey on a stick. I swear there are finger shaped depressions in the ally mast.
  9. #9
    Join Date
    May 2001
    Posts
    25,826
    Default
    They're probably in the same place as the fittings I noticed and intended to pick up just before I started pressure washing and blasted them into the nearest bush.
    One hull good, two hulls better.
  10. #10
    Join Date
    Jul 2009
    Posts
    7,779
    Default
    I have one locker where such things are always put (usually). Small items such as screws and clevis pins go into minigrip bags with a description written on it; e.g. "Don't know what these are for but better keep them in case they're important".
    'The lyf so short
    the arte so long to lerne.'
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
