Can anybody help?
I have changed my engine in my boat from an old iveco engine to a newer one. ive swapped all the marine side of things over and everything seems to be fine apart from one thing. I need new injection pipes made as the old pipe went in between the block and the manifold now they have to go around the manifold I need longer pipes made. can anyone please help?
Its an iveco 8060 25R 4200 engine.
Martin.
Results 1 to 4 of 4
Thread: Iveco marine engine
29-04-12, 12:30 #1
New User
- Join Date
- Apr 2012
- Posts
- 2
Iveco marine engine
30-04-12, 19:18 #2
Registered User
- Join Date
- Feb 2008
- Posts
- 1,699
Martin,
Not 100% sure I recognise the nomenclature 25R 4200, normally 8060 SRM XYZ.
Sounds like you are using truck engine as replacement with the Bosch VE rotary and old marine motor had inline Bosch MW.
Fuel tubes are not cheap from OEM's typically £50 to £70 a jug.
Try Giro Engineering in Southampton http://www.giroeng.com/default.asp?docId=12370
Good luck.
30-04-12, 21:49 #3
Registered User
- Join Date
- Nov 2001
- Posts
- 12,885
Hi and welcome to forum your location is always useful as a forum member may very well be in your area who can help.
01-05-12, 16:57 #4
New User
- Join Date
- Apr 2012
- Posts
- 2
Thanks for the info I'll get in touch with that company.
Martin
Bookmarks
