Ok, but No2. is somewhat obsolete if you simply burn through the stuff using your normal filters? !
Results 31 to 40 of 62
Thread: Fuel Polishing
02-05-12, 09:45 #31
Registered User
- Join Date
- Mar 2002
- Posts
- 6,485
02-05-12, 09:48 #32
Registered User
- Join Date
- Feb 2008
- Posts
- 1,696
As you know I am no Racor convert. As you rightly point out there are other sources, better and less expensive....http://www.designatedengineer.com/
In addition I have sourced restriction gauges from hydraulic hose suppliers, however you need to remember that most filter heads are tapped 1/8th NPT, not BSP.
Leaving a filter pump running vessel unnatended is recipie for flat batteries which is why I advocate using a timer or solar power, all simple stuff.
Once you get much more than 5 inches Hg restriction the flow delta at the filter begins to drop, double that and filter should be considered full.
Not sure why fuel polishing is considered normal on vessels in the US and why people make such a meal of it here. Picture is of a fuel transfer polishing set up with timer, now that is KISSLast edited by Latestarter1; 28-09-12 at 07:29.
02-05-12, 10:38 #33
Registered User
- Join Date
- Jul 2005
- Posts
- 1,717
No the main engine filter will not do anything to clean the tank, the amount that is filtered and sent back via the return is small.
Diesel has some precipates and there is always some debris and water, so the tank gradually gets dirtier. Bio fuel and desel bug problems make this worse.if not cleaned the tank eventually becomes so dirty that it overwhelms the main engine filter. With a desel bug problem a new main filter can clog in minutes. These problems first show up at the worst possible time, when the boat is in rough sea conditions
Polishing the fuel cleans the tank and filters out water reducing the chance of a bug problem. Desel engines need clean fuel and some debris always gets past any filter. A clean tank and fuel will keep the engine healthier and reduce the risk of a nasty surprise when the going gets rough.
02-05-12, 11:10 #34
Registered User
- Join Date
- Jul 2010
- Posts
- 433
ye gads, my eyes are bleeding!
i think, from that site, i'd want something like the following:
the seamax head with the nice drag pointer guage?# 601 BUILT IN BRACKET 3 1/2" PORTS
2 outlet 1 inlet $115.00
Filter Restriction Gauge with Drag Pointer
second pointer stays at highest reading $55.00
02-05-12, 11:27 #35
Registered User
- Join Date
- Mar 2002
- Posts
- 6,485
Surely that should read "could"?
I quite like this idea, but if I put in half a tank and burn through it in two weeks, am I really going to be building up a soup? Cleaning 1 I can grasp; I am struggling with the need for cleaning 2.
Bouncing about at sea presumably stirs up the soup, and if your Racor paper filters are clean after 3000 litres, quite what are you achieving with cleaning 2?
An open question, that is all.
02-05-12, 11:51 #36
Good point gigm, it would be interesting to learn how many boats actually have problems and how old the boats are and just how much if any diesel they have used in the two years preceding the problem.
I realize the 2 method picks up from the bottom of the tank and your engine pick up should be a few inches from the bottom but i have only ever had fuel problems once.............
boat was 15-17 years old.
Fuel gauge was bouncing between empty and reserve (I had about 19 gallons left in a 150 gallon tank)
and it was very rough ( 3 maydays in progress due to sea state)
I changed one prefilter and that was the end of the problem.
I didnt polish my tanks. I just filled them up and carried on to the channel Islands and Back to the Humber without further issue that year or subsequent years.Last edited by DAKA; 02-05-12 at 11:59.
02-05-12, 11:56 #37
02-05-12, 12:10 #38
I think you have a fair point here.
The reason cars don't require frequent fuel filter changes is because the fuel doesn't hang around long enough to build up any bug. It only stays in there for probably a month at most, but in many instances a few days before being used and refilled.
So I think the same would apply in boats; frequent usage must be one of the healthiest preventive treatments you can apply, problems will only occur where the fuel in the tanks remains idle for long periods.
In my case the tanks hold 60 gal each. At normal burn rate of 5L/hr it would take 109 hours running to empty them completely. That's about a year's use for me. Even in our recent week long holiday we only did around 35 hours.
Of course if I had more leisure time I could turn it over more quickly...
02-05-12, 12:16 #39
Registered User
- Join Date
- Jul 2005
- Posts
- 1,717
IMHO its more a matter of when. The crud just continues to builds up in the bottom of the tank. The length of time will vary a lot depending on many factors, particuarly the quality of fuel. The fuel pickup is raised off the bottom so it's not untill it reaches this level, or the tank is stirred up that you will notice a problem.
Unfortunatly more builders are putting in tanks which are very difficult to clean and have no standard access to the bottom to drain off water.
02-05-12, 13:16 #40
Registered User
- Join Date
- Mar 2002
- Posts
- 6,485
I guess I am concluding-personally- that if you boat at sea in mixed sea conditions,and you check your filters and they are always clean then you are not going to gain much by polishing your fuel.
But I accept that if you are having a bug problem, or like Trundlebug,use little fuel over a long period, the set up might have more use.
My engines burn fuel faster than the suggested pump flow rate, so I will have burned all fuel before it polishes it all.
Not knocking the set-up.. just wondering what I personally would get out of it. I would also like to be able to check how much muck the process was picking up.. that doesnt seem immediately obvious to me unless you pull up a chair for most of the day. With the normal set up, I can unscrew and check the paper filters and drain off fuel/water from the bottom of the housing.
Bookmarks
