Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Aug 2002
    Cambridge
    Posts
    2,460
    Default Fire Suppression
    Just had an insurance quote that stipulates an automatic fire extinguisher in the engine bay. I currently have 6 dry powders extinguishers around the boat plus a fire blanket in the galley.
    What do people have in the way of fire fighting aboard.
  2. #2
    Join Date
    Aug 2009
    Scotland.
    Posts
    12,454
    Default
    4 small powders extinguishers, fire blanket, a larger foam extinguisher, 2 automatic fire extinguishers in the engine bay.
    "'...contradictions .... are deliberate exercises in doublethink." Orwell from 1984
  3. #3
    Join Date
    Oct 2008
    Torbay
    Posts
    2,180
    Default
    Auto (gas) in Engine, CO2 in locker, small powders all over about 6. Blanket in Galley. You can pick up a small auto for about 60-70 quid.
    Looking for a sub 30ft fast sailing boat
  4. #4
    Join Date
    Nov 2004
    Norfolk
    Posts
    10,821
    Default
    Two auto gas extinguishers in the engine bay, one small powder in the galley, one office size Co2 in the wheelhouse, one office size foam and one office size powder split between the main cabins. No gas on board, all flammable liquids stored on deck. The only likely ignition source is an electrical fault so battery fuses fitted as well as all items on breakers/fuses and three smoke alarms.
    It's three children sleeping on board that makes me take this level of care . Paranoid? Moi?
  5. #5
    Join Date
    Nov 2009
    Southampton
    Posts
    33,751
    Default
    2 litre foam at the bottom of the companionway, 1kg powder halfway along the cabin side, fire blanket by the cooker, and an auto foam in the engine bay which is quite old but still has good pressure and I'm told there's not much else to go wrong.
    The larger foam was added by me, the rest were inherited.
    Oh, and a bucket with lanyard that generally lives in the cockpit.
    This is a small boat; chart table and galley either side of the companionway and then the rest of the cabin is a U-shape settee berth around the compression post. No separate forepeak etc.
  6. #6
    Join Date
    Jul 2003
    West Australia
    Posts
    11,014
    Default
    Quote Originally Posted by pyrojames View Post
    You havn't said what sized engine and is it petrol or diesel fuel. All these things make a difference to the need to have an auto extinguisher in the engine compartment. My initial thoughts are that they don't want your business if they are demanding what is not a normal fitment or requirement. good luck olewill
  7. #7
    Join Date
    Apr 2004
    Portchester, Solent
    Posts
    4,789
    Default
    Quote Originally Posted by William_H View Post
    Maybe it's got something to do with your name?
  8. #8
    Join Date
    Apr 2011
    Brighton
    Posts
    4,207
    Default
    Automatic extinguisher in the engine bay has been on my "to do" list since buying the boat 2 years ago and this thread has reminded me. Anyone have any links to sites with sizing / mounting best practices? (in my case, engine bay c. 2.5 cubic metres, 40HP diesel). I've got an idea from downloading the installation instructions from a couple of products but not seen anything "independent".
  9. #9
    Join Date
    Nov 2007
    Kingdom of Fife
    Posts
    5,924
    Default
    Quote Originally Posted by laika View Post
    All the ones I looked at specify the volume they are good for. Also they all say only one extinguisher, because if you have two because they will never fire at exactly the same time one pops off and fails to put the fire out because it is not big enough, fire keeps going and sets off number two and once again fails.
    I know they are expensive but they are effective. I also changed most of mine to foam and had a 2 litre in the cockpit and 2 litre ones in the saloon with dry powders in the for and aft cabins
    Peter
  10. #10
    Join Date
    Aug 2009
    Scotland.
    Posts
    12,454
    Default My Rational
    .... mounting best practices? ......
    The suppressants are designed to kill the fire based on a volume of space obviously. I understand that the suppressant is sized to allow for some excess and leakage. However you need to be careful if your engine bay has plenty of space and lots of access for air to get in. In my own case I mounted two of the recommended size port and starboard of the engine to ensure good coverage. My cockpit locker is separated by a loose fitting floor from the engine bay and there is a large gap under the floor that various pipes run through. I believe that this gap would provide good access / egress to the engine room for air or fumes to transverse. My rational was that any leakage of suppressant would be compensated for by the second extinguisher, assuming that it too activated.
    Both extinguishers are mounted about 2/3 rds up from the engine bay sump to the top. This would allow the suppressant to release over the top instead of being directly inline with the block. IIRC the nozzle is pointing at a small shape which would direct the suppressant in a radial manner. Food for thought.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
