Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    pcatterall is offline Registered User
    Join Date
    Aug 2004
    Posts
    2,356
    Default is my propshaft really bent?
    Our cruise along the south coast has come to an end in Poole where the boat is moored awaiting haul out and repairs.
    Back in Newlyn we had an incident where a bolt 'failed' in the prop to gearbox connection.
    The prop thrashed about a bit until we realised what had happened and we were concerned that the shaft may have been bent.
    When reconnected we tried to ascertain if the prop had, indeed , suffered.
    At slow revs it did seem uneven but we were not sure if it had been like that before.
    At about 1000 (engine) rpm it was hard to see any eccentricity, we tried to measure it with a screwdriver which though crude suggested that it was not out by more than around 3mm. We tried her out and there did not seem to be any vibration. We continued the trip checking all the time for vibration and overheating at the stern area.
    All seemed well until we were leaving Poole where the cutlass bearing seems to have failed.
    The local mechanic says the prop is 'horribly bent' by about 10mm but we thought that this was mainly due to the lack of the cutlass bearing ( it was far worse than what we had observed before the bearing went)
    Reading up on the issue ( what we always do 'after the event'!) I understand that my shaft ( about 5 feet long and 1 1/2" diameter ) may 'sag' slightly at the centre until it is spinning at some revs.
    Question is.... does it sound as if my shaft is really really bent beyond the limits at which it may be straightened. Fingers crossed.
  2. #2
    vyv_cox's Avatar
    vyv_cox is online now Registered User
    Join Date
    May 2001
    Posts
    12,208
    Default
    You need to measure it at zero revs, barring the shaft over. Ideally you should use a clock gauge but with care you can see a bend against a reference point to give a small clearance. Either 3 mm or 10 mm would be calamitous, the value should be no more than a few thousandths of an inch (sorry for mixed units, I still have problems thinking metric for small values).
    A 1.5 inch shaft 5 ft long will barely sag at all under its own weight.
    I doubt that a shaft can be straightened sufficiently well. Almost certainly a new shaft.
  3. #3
    Join Date
    Jun 2005
    Posts
    11,342
    Default
    Quote Originally Posted by vyv_cox View Post
    I was going to chip in with my thoughts about the "minor" matter of 3mm but this sums it up well. Best way to tell if a shaft is straight or not is to remove it and roll it on a flat surface. The propeller is more difficult and you would need to send it to a company like Steel Developments for a check.
    If I'd wanted to live in a Banana Republic I'd have gone to South America.
  4. #4
    davidej is online now Registered User
    Join Date
    Nov 2004
    Posts
    1,646
    Default
    Quote Originally Posted by savageseadog View Post
    I just want to add that a new shaft is not an expensive item by boating standards - say £150.
    Try T Norris of Isleworth.
    davidej
  5. #5
    Join Date
    Nov 2006
    Posts
    3,914
    Default
    I think you must have clipped an underwater obstruction so you should be sorting this out with your insurers.
    I may be wrong, but I'm not confused.
    ⛵ Ex-SolentBoy
  6. #6
    Join Date
    Nov 2004
    Posts
    1,622
    Default
    Quote Originally Posted by davidej View Post
    It is normally the fitting of it that stings .......
  7. #7
    Join Date
    Nov 2004
    Posts
    1,646
    Default
    Quote Originally Posted by RivalRedwing View Post
    True - but an easy DIY job. Your post suggests the boat is out of the water. If not, can you find some posts to dry out against?
    davidej
  8. #8
    Join Date
    Aug 2004
    Posts
    2,356
    Default
    I looked up the Norris site before and it looked more like £300!!. Boat will be coming out in the RYMC yard and their contract engineer is going to sort her out with my assistance.
    The 3mm I refered to was aguess at the accuracy I could measure to in situ I think it needs to be around 0.006" but will need to be out to measure it.
    Thanks all.
  9. #9
    Join Date
    Jan 2003
    Posts
    1,686
    Default
    For a 5' shaft at 1.5" dia £300 doesn't seem too far out to me.
  10. #10
    Join Date
    Oct 2004
    Posts
    1,207
    Default
    The bent prop will have tried to shake the shaft but as it is restrained by the shaft bearing this will have taken extra loads causing the water film to collapse and the shaft to run directly on the bearing material. rubber bearings wont last that long in those circumstances.
    I suspect all of your problems are from the prop inbalance from being bent, the shaft can be bent but it needs some force. Some long shafts can get a bend set in if the boat is on the hard for some time but we've only seen this in much bigger shafts.
    I've never tested the theory bu I imagine the vibration from a bent shaft will be quite extreme, the bent prop will be trying to vibrate but the bearing will take all the loads (until it fails) so there will be limited movement. A bent shaft will shake the whole transmission.
    You can see if it's sag by applying support in the centre (work out the weight) and see if it matches the force to take it to the horizontal. Or take it out and roll it as others have said.
    quicKutter rope cutter, shaft and rudder bearings
    www.h4marine.com
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
