Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: VHF splitter.
  1. #1
    Join Date
    Mar 2004
    Posts
    3,196
    Default VHF splitter.
    I am going to fit an AIS receiver and need a VHF feed. Do splitters work and can anyone suggest a good one?
    Many thanks.
    Allan
  2. #2
    Join Date
    May 2011
    Posts
    1,142
    Default
    I would recommend a separate antenna and feed. A new antenna is not that expensive after all. Your VHF is really a piece of life-saving equipment so (for me at least) a splitter is a bad idea.
    Let's make better mistakes tomorrow
    http://tntatsea.wordpress.com
  3. #3
    DipperToo's Avatar
    DipperToo is offline Registered User
    Join Date
    Jan 2005
    Posts
    249
    Default
    Quote Originally Posted by little_roundtop View Post
    +1 - also the AIS aerial is 'tuned' differently to a 'standard; VHF aerial so I am led to believe. Also, if it is mounted on the pushpit, it should work as an emergency VHF aerial.
  4. #4
    pvb's Avatar
    pvb is offline Registered User
    Join Date
    May 2001
    Posts
    15,613
    Default
    Quote Originally Posted by DipperToo View Post
    Not so, AIS uses frequencies in the marine VHF range, so a standard VHF antenna will work fine. However, a splitter isn't necessarily a good idea; maintaining the integrity of the VHF radio system is important.
  5. #5
    Join Date
    Oct 2009
    Posts
    223
    Default
    I have a Glomex RA201 AIS splitter and it does a great job of driving my ICOM VHF, DigiYacht AIS Receiver and stereo. I've not seen any issues with it and AIS performance seems excellent, VHF performance also.
    It's available for about £65 online, but be careful not to accidentally buy the cheaper non AIS version (which just splits out for the VHF and stereo).
    If you do get a problem with the VHF, the splitter goes into a bypass mode when power is removed from it, and in the worst case you can always just disconnect it and plug the antenna in directly to the VHF.
    That said, if you can do it, the extra antenna option *is* superior.
    Which AIS receiver are you getting? Some of the cheaper ones aren't dual channel, they just switch between channels every X seconds. But the Digital Yacht ones are brilliant - mine is the AIS 100 which I picked up for about £120.
  6. #6
    Join Date
    Mar 2004
    Posts
    3,196
    Default
    I have an Icom IC-M501EURO VHF with DS-100 SCA unit. Both have aerials, the DSC one is the old dgps unit one on a pole with the one of my GPS domes. I plan use that with the AIS and split the main aerial between VHF and DSC.
    Allan
  7. #7
    Join Date
    Oct 2009
    Posts
    223
    Default
    The glomex splitter has a VHF connector labelled as VHF and a BNC connector output labelled as AIS.
    I'm not sure whether they are designed to filter the signals based on frequencies, putting the AIS frequencies down the AIS line or not.
    Therefore I don't know if it would be suitable for the task you want it to do, and I suspect the only people that would be sure are the manufacturers.
    For not all that much more than the splitter you could buy an ICOM MC-411 radio with integrated DSC. Not as posh as the 501 but brand new and a lot more compact...
  8. #8
    Join Date
    Sep 2004
    Posts
    3,785
    Default
    Quote Originally Posted by pvb View Post
    Correct - the VHF marine band runs from 156 MHz to 163 MHz. AIS is at the 'right hand' edge of the range - 161.975 and 162.025. Typically, performance will drop off towards each end of the band. A good vhf antenna will have sufficient bandwidth so that even at the extremities of the band it performs satisfactorily, say better than 1.8:1 SWR.
    Some vhf antennas have relatively narrow bandwidth and may not perform very well, lets say worse than 2.0:1 SWR, beyond 160 MHz. Such an antenna might have an SWR of 3.0:1 by the time 163MHz is reached so AIS performance might be compromised.
    An AIS optimised antenna will be centred further to the right of the band so that its performance is good at 163 MHz.
    If you ever intend to use your AIS antenna as a back up for your radio antenna, choose a good quality standard vhf antanna. If you want an antenna specifically for AIS, by all means select an AIS optimised antenna.
    With a splitter, you should use a standard vhf antenna of good quality.
  9. #9
    Join Date
    Mar 2004
    Posts
    3,196
    Default
    Quote Originally Posted by jamesjeffrey View Post
    I have an Advansea AIS RX-100 which is dual channel. It also has a USB output for use down below.
    It cost me £100 earlier this year.
    Allan
  10. #10
    Join Date
    Feb 2010
    Posts
    431
    Red face
    Yes I have this system and it is only an ais receiver but works well displaying ais vessels on my plotter and allowing good vhf performance. As he says, if the splitter fails you can always by=pass it
    +1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
