Not quite. A few minutes research would have got you a wifi card which works with no fiddling. You can't really expect to get a computer with no operating system up and running without having to do a little leg work. There are plenty "how to's" on the web and youtube to help set up whatever you want to.
http://lmgtfy.com/?q=raspberry+pi+wifi+usb+
Results 41 to 50 of 60
Thread: Raspberry Pi - ers, turbo?
27-09-12, 17:55 #41
- Join Date
- Jan 2004
- Posts
- 5,169
27-09-12, 18:26 #42
Registered User
- Join Date
- Jan 2006
- Posts
- 2,218
One of the OPs mentioned openCPN. I can confirm you can compile and run this, zyGrib, xtides on tthe Pi.
01-10-12, 23:54 #43
02-10-12, 08:04 #44
Registered User
- Join Date
- Jan 2006
- Posts
- 2,218
The source code download. There are no current binary downloads.
I could try to make one when Talk Talk fix my broadband.
02-10-12, 12:49 #45
Thanks, I have got as far as the long list of OpenCPN dependencies that have to be installed first. Did that last night. I will try the OpenCPN source download tonight, if I don't get too sidetracked by trying the WiFi dongle.
Good luck with TalkTalk. We've been using them for voice and line rental for four years, but their "Customer Service" still thnks BT is providing the line rental, so TT can't supply broadband. Just about to move to an Eclipse Internet Home Bundle.Last edited by Boreades; 02-10-12 at 12:52. Reason: extra
Four candles?
02-10-12, 17:49 #46
I've got my R Pi working, but I wanted to drive the GPIO from BASIC. I wanted to POKE the relevant code words into the appropriate registers, but quickly discovered that bwBASIC doesn't have PEEK and POKE. Is there a BASIC that will run under LINUX which will enable me to load a 32 bit register having a 32 bit Address?
02-10-12, 18:07 #47
Here's a discussion on various languages using the GPIO WiringPi library
http://www.raspberrypi.org/phpBB3/vi...p?f=33&t=18654
Looks like C and Python are the favourites though :-(
https://projects.drogon.net/raspberry-pi/wiringpi/Four candles?
02-10-12, 18:15 #48
Perhaps Brandy Basic but other languages might be more suitable
02-10-12, 21:25 #49
You need to export the gpio pins, then they exist in the file system down here:
/sys/devices/virtual/gpio
eg for pin22
$ echo 22 > /sys/class/gpio/export
then you have
/sys/devices/virtual/gpio/gpio22 for pin 22 etc:
so you can do
% cat /sys/devices/virtual/gpio/gpio22/value
0
% echo out > /sys/devices/virtual/gpio/gpio22/direction
% echo 1 > /sys/devices/virtual/gpio/gpio22/value
etc and stuff like that
so you can control the gpio from basic just open the file /sys/devices/virtual/gpio/gpio22 and read and write to your hearts content. If that isn't fast enough you'll need to do it from C++ or C
it's just standard linux stuff. I don't have a pi here to test it but the gpio will be down there somewhere in your /sys
you will need to be root
hope that helpsAnd the worms ate into his brain.
02-10-12, 22:47 #50
Boreades, 2nd apprentice, Ed Beynon.
Many thanks, all, for your kind help. It doesn't look too hopeful for my simple BASIC ambitions at present. Brandy BASIC may be a possibility which I am investigating.
I know that it would be best to learn Linux or C, but at my age I am still hoping to avoid having to do that. Thanks for your help with the exporting suggestions Ed.
Bookmarks
