Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Feb 2007
    ionian
    Posts
    315
    Default Removing Sikaflex
    Does anyone know if there is a solvent that can be used to remove Sikaflex from GRP? I need to remove quite a lage area of it from moulded non slip.
  2. #2
    Join Date
    Nov 2009
    living in cheshire, boat in Anglesey
    Posts
    2,480
    Default
    The most effective one I'm aware of is N-dimethylformamide (DMF) which was ( still is ?) used in the printing industry . It causes the PU to become a weak gel like material, but I don't know what effect it would have on the GRP resins !
    DMF is a horrible material though, a liver toxin, it's use requires full face respirator and skin protection. I doubt it's available for non-industrial users. It has the effect of causing alcohol intolerance as well !
    Many mould/ tool cleaners sold for cleaning PU/ release agent residues off tools used in PU processing contain N-methyl pyrrolidone (NMP), but again, it's not widely available and requires similar personal protective measures as DMF. It doesn't smell as bad though !
  3. #3
    Join Date
    Aug 2010
    clyde
    Posts
    77
    Default
    Acetone maybe? never tried it on sikaflex though
  4. #4
    Join Date
    Feb 2009
    Solent
    Posts
    155
  5. #5
    Join Date
    Jul 2002
    Farnham, Surrey
    Posts
    19,772
    Default
    Quote Originally Posted by Skatt View Post
    I will put a pound to a penny that stuff won't dissolve Sikaflex when its gone off!
    Semper aliud
  6. #6
    Join Date
    Jul 2002
    Farnham, Surrey
    Posts
    19,772
    Default
    Quote Originally Posted by red beard View Post
    Doesn't work - guess how I know?
    Semper aliud
  7. #7
    Join Date
    Jul 2001
    Australia, East coast.
    Posts
    6,006
    Default
    I have always used a wooden chisel, cut from scrap timber about 30 degrees, the timber is hard enough to abrade the sealant but soft enough to not damage the gel coat.
    Finish with Acetone on cheese cloth.
    Good luck and fair winds.
    Growing old is unavoidable. However, growing up is still optional.
  8. #8
    Join Date
    Nov 2009
    Southampton
    Posts
    33,859
    Default
    On smooth GRP a sharp blade can skim it off. But I wouldn't fancy having to remove it from non-slip like you do.
  9. #9
    Join Date
    Apr 2006
    Portsmouth, UK
    Posts
    2,711
    Default
    Are you sure that it is Sikaflex that you need to remove.. or is it just a silicone (or other) based sealant?
    The Sikaflex 291 datasheet here unfortunately says 'Once cured, the material can only be removed mechanically.'
    Perhaps it is a different Sikaflex in which case perhaps the datasheet specific to that type will help... Most Sikaflex sheets unfortunately say the same.
    Remaining Sikaflex datasheets here
  10. #10
    Join Date
    Feb 2007
    ionian
    Posts
    315
    Default
    Thanks for the suggestions. It is sikaflex and I am not sure how to get hold of the industrial solvents mentioned in greece. I will ask some greek friends and hope that the initials are universal. The wood chisel sounds interesting because the non slip is in a square pattern so it may be possible to work in two directions with a grooved piece of wood.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
