Results 1 to 7 of 7
  1. #1
    jag22 is offline Registered User
    Join Date
    Jun 2012
    Posts
    62
    Default Outboard Gear Oil Type
    I have two old outboards that (usually) run OK. I'd like to replace the gear oil in them before use this year. Can anyone advise on the type of oil that I should get? As usual I went online to purchase something and found there are 100 different types, so I ended up confused.
    The motors are:
    Yamaha P65 3.5hp
    Evinrude Yachtwin 6hp
    Can the same oil be used in both of these ageing outboard relics?
  2. #2
    Join Date
    Jul 2002
    Posts
    27,506
    Default
    Any outboard gear oil thats around EP 80W 90.
    If you find a bog standard grade and a more expensive grade (for large modern outboards) use the bog standard grade.
    Quicksilver is a brand you will find almost everywhere.
    I use ordinary automotive EP90 gear oil in my Evinrude but I am not recommending that you do. Outboard gear oil contains emulsifiers and corrosion inhibitors to counter the effects of water ingress.
    Sea Wych Owners Association website.. www.seawych.org
  3. #3
    Join Date
    Jun 2012
    Posts
    62
    Default
    Brill. Thanks.
    Like this oil on ebay and get a pump to pump it in from the bottom?
    http://www.ebay.co.uk/itm/Quicksilve...item256df5388d
  4. #4
    Join Date
    Jul 2002
    Posts
    27,506
    Default
    Quote Originally Posted by jag22 View Post
    Brill. Thanks.
    Perfect!
    But dont pay that much and 4.50 postage if you can get to a local Force4 or other major chandler
    Get a pump if you like but you may need different connectors for different make outboards. I bought one lot in a squeezy bottle. I refill the same old squeezy bottle.
    Its advised to to renew the seals on the drain and level screws. the E'rude probably has flat nylon washers under the heads of the screws. Dunno about the Yamaha but replace with the same type (some E'rudes have O rings and very slightly different screwplugs)
  5. #5
    Join Date
    Jun 2012
    Posts
    62
    Default
    much appreciated, thanks.
  6. #6
    Join Date
    Jul 2002
    Posts
    27,506
    Default
    Seen my added note about price??
  7. #7
    Join Date
    Jun 2012
    Posts
    62
    Default
    Didn't see that, thanks. Yes it's a bit of a rip off isn't it. I'll have a look round. Soon adds up doesn't it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
