Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
  1. #1
    Join Date
    May 2001
    Berkshire, Somerset, Hampshire
    Posts
    3,917
    Default Confidential reporting
    Thanks to the many of you who have contributed here. Some 187 posts later, many of them actual incident reports, the problem is clearly not going away.
    However, concern is one thing but getting that to translate across to any means of action is another. That is especially so when incidents caused by collision with flotsam and jetsam or fouling by rubbish and fishing gear are so rarely getting thrown up in MCA and RNLI figures. It tends to suggest that most occurences are getting dealt with by owners themselves and via the assistance of non-lifeboat tows, commercial yards and private divers. Statistically, the problem doesn't exist, so it is hardly likely to get looked at by government. That is the problem the RYA faces when being asked to challenge the status quo.
    For that reason the RYA is now encouraging boatowners to start filing incident reports on the confidential system run by the charitable UK Confidential Human Factors Incident Reporting Programme, or CHIRP for short. This organisation was founded in the early 1980s to serve the aviation industry, but launched a maritime programme in July of last year with the assistance of government funding. Although weighted heavily towards commercial interests, the advisory board includes Steve Johnson, the RYA's Cruising Manager and Nick Parker of the British Marine Federation.
    You can read more about CHIRP by , which is a little quirky but contains some useful background if you want to understand who you might be offering your reports to. We are now also hosting the relevant reporting form on ybw.com. This form looks a little daunting at first but only if you pay too much attention to the questions asking whether you are a captain or chief engineer and whether you serve on a tanker or cargo ship. You can access it at <A target="_blank" HREF=http://www.ybw.com/pdf/CHIRP_report.pdf>http://www.ybw.com/pdf/CHIRP_report.pdf
    At the moment CHIRP has received barely more than a handful of reports covering fouling and collision incidents, so any new feedback will raise this matter further up the agenda, or perhaps at least put it on the table.
    <hr width=100% size=1>
  2. #2
    Join Date
    Mar 2003
    falmouth
    Posts
    16,373
    Default Re: Confidential reporting
    The thing that has always puzzled me about pot buoys is why, when so many of them are put in well trafficked places and either marked badly or with sinking marks, no one has ever sued the fisherman for the damage caused. Surely they must have some"duty of care" to mark them effecively if they are placed where boats might go.
    this post is a personal opinion, and you should not base your actions on it.
  3. #3
    Join Date
    Nov 2001
    UK
    Posts
    192
    Hi all,
    CHIRP has been part of the aviation safety scene for years, and has achieved some notable successes. I am sure that under Peter Tait's direction, the marine CHIRP will grow to be a worthwhile mechanism.
    On the subject of unmarked pots, I honestly don't know why we don't all simply cut the lines of those we find. This would be the simplest and most effective way of solving this problem. Two wrongs don't make a right, but as Kim so ably explains, the problem is not going to go away without some action, somewhere.
    So, I echo Kim's recommendation. Give CHIRP your support, and use it - it is only one tool in the safety kit, but it's a sharp one.
  4. #4
    Join Date
    Nov 2001
    Southampton ,England
    Posts
    226
    Hi
    " I honestly don't know why we don't all simply cut the lines of those we find. This would be the simplest and most effective way of solving this problem."
    I said to myself if ever i picked up a pot bouy this is what i would do in the future, but another fourm member made a very good case for not doing this in as much as they will be probably be marked with a GPS position ,so not to much trouble to retreive and secondly if the pot is not found and left on the botton, crab goes in eats the bait then starves to death then the next crab goes in eats first crab then starves to death and so on and so on.
    Dave.
  5. #5
    Join Date
    Jan 2002
    Hampshire
    Posts
    1,033
    I would rather 100 000 crabs starve to death than a yottie die as a reult of fouling the pot marker.
  6. #6
    Join Date
    Jan 2004
    the grenadines
    Posts
    395
    I respectfully suggest caution if you intend to cut the lines of fisherman's gear which are not fouling your vessel. Some fisherman are likely to react inappropriately if they find you doing this. Things could get violent. It would be totally wrong but a real possibility.
  7. #7
    Join Date
    Nov 2002
    Hampshire
    Posts
    970
    Default Calshot - Lepe
    Not an incident so, presumably, of no interest to CHIRP, until someone is injured or dies.
    The entire inshore area between Lepe and Calshot is now totally peppered with dozens & dozens of wholly inadequately marked pot bobbers - directly on the lay-line for small boats heading to, or returning from, the West.
    With ABP's insistence that the main channel is a no-go area for small craft, these craft are largely forced to the North of the channel and therefore into direct conflict with this maze of bobbers with their inherent dangers.
    Even the most inept barrister would surely have no problem whatsoever, in proving the relevant authority, whom I assume to be ABP, to be negligent in their duty to ensure safe navigation.
    Is this just another instance of the bloody mindedness of fishermen carrying the day, because no one has the guts to take them on - legally or on their own terms?
  8. #8
    Join Date
    Apr 2004
    Devon
    Posts
    292
    Default Re: Calshot - Lepe
    Rope round your prop is like getting a puncture it might never happen but you still carry a spare? if you have an engine you need a rope cutter...weve picked up stuff...bits of nets line etc just floating around off spain more than once, its not always going to be attached to a pot...fishing line (if long enough) with hooks and floats can cause as much damage. There is a new cutter (in Y World this month quickutter? ) that has even cut ss wire so in most situations now you will not get trapped or have your drive system disabled. Its something Ive always planned for and have mask and knife always ready, just in case.
  9. #9
    Join Date
    Nov 2001
    UK
    Posts
    192
    Andrew Weir, in his excellent book 'The Tombstone Imperative', explains why it is that people generally DO have to die before change is actioned.
    It would be extremely straightforward to enact legislation requiring all pot markers to be marked to a standard (flag, radar reflector, minimum pole height, automatic flashing light active at night, with identification marks indicating who the owner is).
    My experience outside boating suggests that this legislation might rapidly follow a fatality, but will not come about without one. Really, we (reasonable people) should be able to do better.
    So, how do we tackle this serious problem?
    Is education (of the offenders) a possible answer? The CAA's general aviation safety department have made a huge success of 'roadshows' around the country preaching aviation safety messages - do we need something for boaters and fishermen? I think this could be a real winner - with RNLI involvement, it could be a strong tactic.
    Should we (the motor boat community) get together to design and manufacture a 'standard' pot marker in sufficient numbers to equate to very low cost, and then actively market them - or offer them for free - to the fishermen?
    Should we be more aggressive in tackling 'offenders' - when your sterngear is fouled, how could you track down the offending fisherman and prosecute, given present rules?
    The present debate over light dues is a parallel. Most bouyage is handy, but not essential, for most of us. It doesn't provide genuine improvement in our ability to avoid hazard or reduce risk. Proper pot marking would, so do we need to join the two issues together somehow?
    Go on, let's have some lateral thinking...
  10. #10
    Join Date
    May 2003
    West Midlands
    Posts
    743
    Surely, most of our concern is to do with cost and inconvenience. Personally I have no problem with a visible well marked pot that can be avoided quite easily, my concern and I presume that of others, is the dark, ex oil bottle, barely apparent above the surface. Almost invariably situated in a wholly inappropriate spot.
    Thus perhaps the only course open to us as a "group" is to loudly publicise our intentions as a "group" to dispense with any inappropriately positioned, unmarked, invisible pot markers. I am talking "en masse", we should declare without fear or favour that these things are a menace and will not be tolerated after a certain predetermined date. Simply, stop, lassoo incorrect pot marker and cut it off. if we joined forces publicly and stated that was our intention in the relevant periodicals, we would probably never have to cut one at all. They would either be removed or marked correctly post haste. Its only because we accept non compliance it occurs.
    I don't want to see some one deceased to affect change as mentioned earlier, wait for legislation? Give me a break.
    When enough "cost and inconvenience" has been caused or even just threatened to these people, I will not honour them with the title Fishermen, we will see change. If it were an action taken by many, there simply isn't enough "violence" to go around us all. Paul
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
