Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Join Date
    Jun 2012
    Gloucestershire
    Posts
    164
    Question Gear oil for Mercruiser alpha one?
    Looking to change gear oil in my alpha one drive..
    Is there a difference between normal motor oil a marine oil apart from the price, I have heaps of different types of oil in the garage for bikes, cars etc
    I cant see why marine oil whould be any different when its doing the same job?
    The only think i need to know is what weight is recommened?
    Thanks, James
  2. #2
    Join Date
    Nov 2008
    Boat (Southampton)
    Posts
    8,187
    Default
    Quote Originally Posted by blackrandomapple View Post
    Thanks, James
    James, in my opinion it's not worth the attempting to save a few quid for an essential part of keeping an Alpha One drive worth a couple of K working correctly. Others may differ in their opinion but the safe option is to go with the manufactures recommended lube.
  3. #3
    Join Date
    Jun 2012
    Gloucestershire
    Posts
    164
    Default
    Hi, Thanks for the reply.. Do you know what the recommened oil is?
  4. #4
    Join Date
    Jul 2011
    Denmark
    Posts
    2,261
    Default
    The manufacturer recommends oil that meet certain properties and are specifically designed for the use (eg. tolerant to moisture).
    You may skip the engine manufacturer private label oil, but should stick to recommendation. Even for gear oil (which is not engine oil).
  5. #5
    Join Date
    Nov 2008
    Boat (Southampton)
    Posts
    8,187
    Default
    Use the High Performance lube James, the bluey green stuff. Some sites say it's ok to use the premium lube (bronze coloured) but I've always been advised to use the former
  6. #6
    Join Date
    Jun 2012
    Gloucestershire
    Posts
    164
    Default
    Im not to worried about the cost, I just didnt want to spend money when i could have used something i already have! Will get on the case and go to my local marine supplies and get the good stuff!!!
  7. #7
    Join Date
    Nov 2008
    Boat (Southampton)
    Posts
    8,187
    Default
    Are you changing the lube yourself James? presume you know about filling the Alpha One (gen II?) from the lower drain hole if you are? Are you changing the impellor whilst you're at it?
  8. #8
    Join Date
    Jun 2012
    Gloucestershire
    Posts
    164
    Default
    I only bought the boat this year and was told it was serviced and didnt need another service untill end of season, i wanted to change the gear oil as a peace of mind. Yes i will be doing it myself but i wont be changing the impeller just yet. Im not sure if it Gen I -II was made in 1992 if that helps?
  9. #9
    Join Date
    Nov 2008
    Boat (Southampton)
    Posts
    8,187
    Default
    I think they stopped production of the Alpha 1 Gen 1 drives around 1991 so if I right (I may be wrong) it could be either. post a picture of the drive to be sure.
  10. #10
    Join Date
    Mar 2002
    Posts
    14,757
    Default
    Quote Originally Posted by oGaryo View Post
    Use the High Performance lube James, the bluey green stuff.r
    You mean the original Merc oil, AKA "green death"?
    Beware! In this specific case, using something else is not a matter of saving a few quids, but rather of saving the outdrive.
    We discussed that in this previous thread:
    http://www.ybw.com/forums/showthread.php?330662
    ...and you can find much more about that in the offshoreonly US forum, if you're interested.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
