Page 3 of 10 FirstFirst 12345678 ... LastLast
Results 21 to 30 of 96
  1. #21
    Join Date
    Mar 2009
    Northern Ireland
    Posts
    380
    Default
    Does the communication need to be two way or just for your orders from the helm to be heard?
    If no need for a response I would use the boat stereo system in some way, assuming it can be heard everywhere.
    Does your VHF have a PA function?
    Alternatively there is a "walkie talkie" bluetooth app for Iphone that works well with an ok range. I use it with standard iphone headphones.
  2. #22
    Join Date
    Jun 2007
    Live in Kent, boat in Canary Islands
    Posts
    16,245
    Default
    How about a central device that communicates with several Bluetooth earpieces, and allows the wearers to converse with each other. If one goes out of range, it sounds an alarm.
    Nothing concrete yet, but I'm considering building one if there is enough interest.
  3. #23
    Join Date
    Oct 2009
    Posts
    464
    Default
    How about if the mrs doesn't do as she is told taking the mafia aproach
    Nothing concrete yet but I'm thinking of building one
  4. #24
    Join Date
    Oct 2009
    Posts
    464
    Default
    Edit - need another p. damn this cheap french wine
  5. #25
    Join Date
    May 2006
    Finland
    Posts
    2,178
    Default
    Quote Originally Posted by Hurricane View Post
    Yep, I'm working on an idea like this
    Your idea falls over if the phones are roaming - expensive connections etc.
    What about two of those cheap handsfree bluetooth headsets for mobile phone's as you say.
    They would then need a bluetooth server (maybe an Android phone or something) to connect them together.
    Or maybe modify one (or find one) to be a server for the other.
    A bit like this idea http://www.cardosystems.com/cardo-bk/cardo-bk-1
    Or (even closer to your idea)
    Two smart phones (Android etc) connected by some kind of VoIP connection using WiFi. Then each phone with a handsfree bluetooth headset.
    A bit fanciful - me thinks
    It's got to be easy or it won't get used.
    Come on guys
    The technology exists - and its cheap
    This http://www.asterisk.org/ or something similar might work, but as you say, quite a lot of moving parts...
    That cardo seemed interesting, i wonder about the 500 mtr range though. In any case should be enough for a boat. That might be the answer?
    Re mobile phone: I don't know the general roaming charges around there, but i would imagine it would take quite a few berthings to off-set the cost of a dedicated radio system? On the plus side you have simplicity.
  6. #26
    Join Date
    Nov 2005
    Sant Carles de la Rąpita
    Posts
    6,834
    Default
    Quote Originally Posted by MarieK View Post
    Two way is essential - Duplex would also be useful - i.e. both being able to talk at the same time.
    Yes - our VHF does have a PA function and I do use it - but only works when SWMBO is on the bow.
    The "walkie talkie" app seems the best "off the shelf" idea at the moment but does seem a little complex to set up when you need it quickly.
    Ideally, you just want to grab a couple of headsets and use them.
  7. #27
    Join Date
    Nov 2005
    Posts
    6,834
    Default
    Quote Originally Posted by nigelmercier View Post
    Yep - thats exactly the idea that I think would work.
    I think it could be describe as a Bluetooth server.
    Perhaps the hardware could be a smart phone placed strategically somewhere.
    Then, maybe, just picking up a couple of headsets would work simply - maybe.
    However, I'm not sure you can pair more than one device to a bluetooth connection.
  8. #28
    Join Date
    Sep 2004
    UK
    Posts
    4,520
  9. #29
    Join Date
    Nov 2009
    Southampton
    Posts
    35,300
    Default
    If she doesn't like you raising your voice slightly, I'm amazed she tolerates being ordered about over a megaphone!
  10. #30
    Join Date
    Sep 2001
    Posts
    152
    Default
    Assuming your VHF PA has talkback function, how about a second speaker in the cockpit and a switch to select bow or cockpit?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
