Page 1 of 9 123456 ... LastLast
Results 1 to 10 of 87
  1. #1
    Join Date
    Mar 2005
    Buckingham
    Posts
    12,967
    Default 2nd tiller pilot has just expired
    I started this trip with two tiller pilots
    an ST 2000 that came with the bioat that was amazing
    at night it was better on the helm than any human
    but it rained and it stopped - now all it does is beep like a sad seagull chick
    the other was the st1000
    less good but I have been using it since I started KTL so it had a seven year bashing
    It has got a bit wet but a few minutes under the fan heater and it starts again
    not this time though
    after the journey between Orkney and Eirbol when it got wet a few times it has also expired
    the fan heater treatment produces no cure
    does anyone have an old but unwanted one they are willing to swap for ktl DVds
    yours
    Ron Hopeful
    PS - here is the story of the journey
    http://www.keepturningleft.co.uk/sai...-of-times-and/
  2. #2
    Join Date
    Apr 2009
    Posts
    5,325
    Default
    Quote Originally Posted by dylanwinter View Post
    Was the wetting with salt water this time, or fresh? Maybe it there's salt in there a bit of a rinse prior to the fan heater cure might help. Slim chance admittedly...
  3. #3
    Join Date
    Nov 2012
    Me: Oxford & Dereham.Boat:Oxford to North Norfolk (usually)
    Posts
    113
    Default
    Seems to be a common problem with the raymarine pilots.
    I have a poly bag that a roll of fibre glass mat came in, to slide over it.
  4. #4
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    42,581
    Default
    Won't Raymarine repair one of them in return for a bit of good publicity on KTL
    Pretend to be Ellie !
  5. #5
    Join Date
    Apr 2005
    Shoreham - up the river without a paddle.
    Posts
    1,143
    Default
    Quote Originally Posted by lpdsn View Post
    Mine have died about three times. A rinse followed by a warming has worked wonders thus far...
    I also put a water absorber in, but it got in the way of the works so got the heave-ho last month.
    They really need to be put in a waterproof bag if being sailed enthusiastically (or in scotch mist perhaps)
  6. #6
    Join Date
    Jun 2009
    south yorks
    Posts
    5,529
    Default
    waterproof bag we sewed one with plastic tent window stuff
  7. #7
    Join Date
    Dec 2002
    France
    Posts
    24,489
    Default
    yours
    Ron Hopeful
    I can sympathise. Mine (ST2000) stopped 2 months out of warranty. The estimate to repair was more than the original cost. The Raymarine distributor told me I shouldn't have let it get wet.
    A marine machine intended to work in the cockpit......!!!
  8. #8
    Join Date
    Aug 2004
    West Coast of Scotland
    Posts
    4,488
    Default
    Were you applying the fan heater to the complete unit or after taking it apart?
    I have found that rinsing the circuit board with fresh water then leaving it in the sun to dry out completely (both sides) usually works. Note the colour coding of the various wires before unplugging them. To prevent condensation after re-assembly you also need to get all the remaining water out of the case with paper towels (difficult: it's a complicated shape with lots of nooks and crannies) followed by hot air or sunshine as available.
  9. #9
    Join Date
    Sep 2010
    West Sussex / Hants
    Posts
    27,817
    Default
    Dylan,
    I have found Raytheon tech support ( as the golden rule in life anywhere, don't go near sales / admin ) offer brilliant advice & support inc the cheapest way around snags.
    Good luck, I agree the ST2000 is a brilliant bit of kit.
    Anderson 22 Owners Association - For info please ask here or PM me.
  10. #10
    Join Date
    Feb 2010
    Posts
    2,495
    Default
    Dylan check your plug and socket connection is good. Corrosion and one of the pins not making contact with the other pushed out of joint caused a similar malfunction. I found the fault after trying another know good TP.
    Sometimes enough connection to fire up display but as soon as you draw any current it goes awol with a beep?
    Now Sailing Bluenote II Hanse 301 based Y Felinheli Dock.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
