Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Aug 2004
    Posts
    4,672
    Default Air intake silencer for 4108
    Anyone had success with this yet? I purchased the 'recommended' ( ford ranger?)box but it is a bit like a dustbin in size and I am struggling to find a good place to fit it.
    If reports are good I will struggle on but may need something smaller.
  2. #2
    Join Date
    Nov 2013
    Perth WA
    Posts
    2,182
    Default Re: Air intake silencer for 4108
    I've installed a 4.108 in an "engine-room" and I was hoping I would get away with some good insulation.
    Is that not sufficient?
    Did you see this thread?
    http://www.sailnet.com/forums/diesel...-silencer.html
  3. #3
    Join Date
    Aug 2004
    Posts
    4,672
    Quote Originally Posted by coopec View Post
    Noise Insulation is fine/essential but a surprising amount of noise is generated where the air is sucked in. Fellow forumites report big reductions in noise and I have personal experience of big noise reductions when using an air intake silencer on eberspacher heaters.
    No, not seen that thread but have seen many similar.
  4. #4
    Join Date
    Nov 2013
    Perth WA
    Posts
    2,182
    could you suck the air in from the (say) lazarette?
  5. #5
    Join Date
    Dec 2007
    S.W. France
    Posts
    7,681
    Back in the 80s I installed a Sailor Silent Set generator in the engine room of the company ketch. It had very effective exhaust mufflers ( Vetus) and a longish black plastic intake muffler that reduced the intake noise. Engine was a BMW ( Hatz) single and in it's insulated box one could talk right by it without raising one's voice. Not sure who made the intake muffler, but it might have been Vetus.
  6. #6
    Join Date
    Aug 2004
    Posts
    4,672
    Yes coopec, I guess that drawing the air in from elsewhere ( and where there is plenty of clean air and noise is not an issue) would reduce the noise.
    the hose that DownWest mentions sounds like the ones for the eberspachers ( which are effective) these seem to be the ( standard) 25mm diam corrugated plastic hose enclosed in a larger ( 50mm?)diameter corrugated plastic hose. I may take one to bits but guess that the inner hose will have holes in it so that some air circulates/is drawn through the outer 'jacket'. With luck We may get an 'expert' to explain all this!!
    Fitting a larger version of that type of inlet silencer would appeal to me more than the large plastic dust bin thing I am considering!!
  7. #7
    Join Date
    Dec 2006
    Midlands
    Posts
    1,686
    Quote Originally Posted by pcatterall View Post
    I used a remote air filter from a diesel car in a scrap yard, worked well and cheap also you can mount it where suits best.
  8. #8
    Join Date
    Sep 2003
    Cambridgeshire
    Posts
    1,391
    That is exactly what is in the Eberspacher silencer... along with some foam in the outer pipe..... They work surprisingly well for what they are....... perhaps its vodo???
  9. #9
    Join Date
    Dec 2007
    S.W. France
    Posts
    7,681
    The bit I was talking about was not a hose, it was a moulded plastic job that looked a bit like some of the Vetus mufflers for the last bit of an exhaust run.
  10. #10
    Join Date
    Nov 2004
    Essex
    Posts
    516
    My old 108 had a flame gauze fitted directly to the manifold with an automotive cleaner on top. I think that if you have to use the "Thermostart" which involves flames ! A flame trap might be good idea, or some metal duct before adding any plastic.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
