Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    Dec 2009
    South Devon
    Posts
    116
    Default Diesel fuel additives
    Anyone got any preferences re Soltron and Grotomar enzyme fuel treatment. I have just had a major engine problem/overhaul and want to ensure I look after my motor to the best of my ability. Cheers!
  2. #2
    Join Date
    Sep 2006
    Gloucestershire
    Posts
    1,471
    Default Re: Diesel fuel additives
    Starbrite Startron ��
    Anyone seen Grabthar's hammer?
  3. #3
    Join Date
    Nov 2009
    Just on the Clyde.
    Posts
    714
    Looking after your engine is servicing it properly, adding diesel bug inhibitor will help prevent problems in the fuel tank and keep lines clear.
  4. #4
    Join Date
    Feb 2008
    Farndon
    Posts
    2,632
  5. #5
    Join Date
    Mar 2010
    Sunny Northumberland
    Posts
    992
    Quote Originally Posted by MartynG View Post
    That's what I've used without problems for the last 6 years.
  6. #6
    Join Date
    May 2001
    UK East Coast
    Posts
    34,411
    I used to use Soltron/Startron, but found further bug growth. I changed to using Marine 16 and Grotamar (alternate every 6 months or so) and find they are better.
  7. #7
    Join Date
    Sep 2006
    Gloucestershire
    Posts
    1,471
    Grotamar produces prodigious amounts of solids when dealing with the bug which bunged up the fuel lines on our boat.
  8. #8
    Join Date
    May 2001
    UK East Coast
    Posts
    34,411
    Quote Originally Posted by robmcg View Post
    Solids get filtered out; bug is slimey and blocks filters.
  9. #9
    Join Date
    Jan 2012
    South Coast
    Posts
    4,865
    Keep the fuel clean and dry and you won't need snake oil.
    Build a simple polishing rig, and grease the threads on your deck filler.
    Interested in Corvettes PM me for details of the Corvette Motorboat Association
  10. #10
    Join Date
    Dec 2007
    Boat: Falmouth. Work: Cambridge
    Posts
    1,310
    An observation is these additives seem to be a UK obsession and those countries which use any old road fuel, so with lots of biodiesel aka FAME, just don't seem to have the 'problems' reported in the UK.
    As a small indication of this I compared two near identical boats, mine 10 years old and always wintered in the UK with red diesel since new, and the other 13 years old and kept in Athens which had been filled with any old road diesel and whose tanks had never been inspected, let alone cleaned. Both had done about 2000 hours motoring. The Greek one's tank was much cleaner!
    My conclusion is that the best thing is to keep your fuel clean and with no water at all in the tank. Additives are only an imperfect palliative for sloppy housekeeping.
    My suggestion for good practice is:
    1. On lay-up make sure there's no water in the tank. Open it up and look.
    2. Run the tank empty at the end of the season, maybe even throw away old fuel, or use it in the car (see #4)
    3. On re-launch make sure there's no water (condensation is unlikely but one might as well be sure)
    4. Fill with diesel. Road fuel is best, not the old red diesel which has been ageing in the marina's tanks. It's very probably cheaper anyway since most marinas rip one off even allowing for the 60/40 split.
    5. On arriving in a port (or home) after a voyage do not fill the tank just becauee you've used a bit. Wait 'til nearly empty and then refill with new, clean, fuel.
    I know it's contrary to what most do, but I genueinely think it better practice.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
