Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2007
    Westwick - Essex
    Posts
    62
    Default Raymarine ST60 Tridata - Speed Log Problem.
    Hi I am hoping someone can advise.
    I have a new to me Raymarine ST60 Tridata and the displayed speed is approximately half of the GPS speed despite a spotless clean Transducer.
    The Depth and Sea Temperature all looks o/k.
    Transducer you say and I would tend to agree but I have mixed test results which is confusing.
    I am assuming the Transducer is an M78712 although I cannot confirm this, all the connections look o/k! Spinning the paddlewheel by hand and I get a reading on the display – however the Raymarine test instructs you to connect a multimeter between the removed green and shield connectors and slowly rotate the paddle wheel. You should get an open and closed circuit for each quarter turn – I get nothing!!
    I can get a replacement Transducer which is the E26031 I believe, but just wondered if it was a waste of time giving the test results?
    Has anybody had similar problems or should I upgrade the whole unit?
  2. #2
    Join Date
    Aug 2004
    Cumbria; U.K.
    Posts
    2,746
    Default Re: Raymarine ST60 Tridata - Speed Log Problem.
    Obvious question, but have you calibrated the speed readout against the GPS as described in the manual?
    Can't suggest a reason for the lack of pulses when you connect a multimeter, but it must be outputting something to get a reading at all.
  3. #3
    Join Date
    May 2001
    UK East Coast
    Posts
    27,773
    Quote Originally Posted by moresparks View Post
    Did you try this with the other transducer wires still connected to the power source?
  4. #4
    Join Date
    Apr 2007
    Westwick - Essex
    Posts
    62
    Many thanks for your speedy responses.
    I must confess I have tried calibrating but without success – the Speed is so far out the increment values have little effect.
    “Did you try this with the other transducer wires still connected to the power source?”
    I must confess all other transducer wires were connected at that time – that is something I could try.
  5. #5
    Join Date
    Aug 2016
    Posts
    264
    Sounds like a failure of the paddle wheel sensor - which is also measuring speed through water - not SOG which is provided by GPS.
  6. #6
    Join Date
    Jul 2015
    Posts
    99
    Had a similar problem with a NASA unit and found that the paddle wheel should have had two magnets attached. One was missing. Might be the same with your unit?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
