Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Join Date
    Sep 2010
    Manchester UK
    Posts
    39
    Default Re: Prestige 32 question
    Quote Originally Posted by Whitelighter View Post
    Hmm, not got any and can't host them even if I had.
    All I will say is I am very very impressed with it. It's only weakness is the grill - because it's shite. Ok, will probably do a toasted cheese sandwich but won't do bacon etc.
    Anyway, the model is a daewoo KOC-9Q4T. I did loads of Rea search and it's the smallest full over microwave I could find.
    It does microwave, convection oven, grill (badly), combination (convection with MW), has a warming function and self steam cleans.
    Buy it here for £90 http://www.appliancesdirect.co.uk/p/...iABEgKxavD_BwE
    It says don't put it in a cupboard, but I have and it's fine
    Thanks for the info Whitelighter, I'll check that one out.
  2. #22
    Join Date
    Apr 2014
    South East Wales
    Posts
    5,648
    UPDATE: I looked at the Daewoo KOC-9Q4T combi microwave - unfortunately, it's too wide, which is a pity. The width of most combi microwaves has ended up being a massive problem. The only ones I could find that were small enough (not many) all had terrible reviews.
    I have ended up finding a Dualit mini oven that will work with the dimensions and it also seems to have reasonable reviews. Going to get it this week and hopefully install this weekend. Will update thereafter.
    https://www.dualit.com/products/mini-oven
    Nisbets look to be the cheapest even with the VAT added on, assuming you can collect and don't incur a delivery fee.
  3. #23
    Join Date
    Mar 2003
    West Midlands
    Posts
    3,088
    I measured the gap as 464 x 292mm and reckon that this oven from argos would fit. Plenty of width either side of oven when you get it thru the gap http://www.argos.co.uk/product/9015742
    Per Ardua Ad Nauseam
  4. #24
    Join Date
    Apr 2014
    South East Wales
    Posts
    5,648
    One I had not stumbled across. It looks really good. I have not been to Nisbets yet, so, I'll have a closer look. Only worry is the power. I'm pushing my luck with 1300 watts on the other oven. I want it to be able to run off batteries and an inverter and we are going to have to massively up the battery capacity as it is.
  5. #25
    Join Date
    Apr 2014
    South East Wales
    Posts
    5,648
    Just ordered the one from Argos... Mr Shan is going to have to sort out the power side.
  6. #26
    Join Date
    Mar 2003
    West Midlands
    Posts
    3,088
    Do you need to have it powered from an inverter? I think we spend less than 10 days a year overnighting without shore power and on those evenings we usually eat out or make pasta on the hob
  7. #27
    Join Date
    Apr 2014
    South East Wales
    Posts
    5,648
    It would be preferable but I can make do without it if need be. I used the gas oven on our other boat quite a lot. Probably just need a bit of mental re-calibration.
  8. #28
    Join Date
    Feb 2008
    Farndon
    Posts
    3,012
    My chief officer wouldn't let me buy a boat without a gas oven.
    I didn't like to argue.
  9. #29
    Join Date
    Apr 2014
    South East Wales
    Posts
    5,648
    Update: Turned the oven on at home and pleased we did. It off-gassed quite a lot - wouldn't want to do that in the boat! The oven gets pretty hot on the outside, so we will have to line the space with some heat proof insulation. Fortunately, we have some heat blanket left from when we line the Porsche bumper. In addition to this, I think we will need to install a fan to shift some of the arm air.
    The oven seems pretty reasonable for a doll sized oven. You could do certainly a small chicken or a guinea fowl without any hassle. It seems to be quite sturdy and robust. Gets to temperature quickly and is fairly simple to understand. I'll update once it has been installed and we have cooked a meal in it.
  10. #30
    Join Date
    Mar 2003
    West Midlands
    Posts
    3,088
    All good so far then. Look forward to the update.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
