Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Whisker poles
  1. #11
    Join Date
    Jun 2003
    Orford, Suffolk, UK
    Posts
    1,563
    Default Re: Whisker poles
    Re. length of pole, I once made a timber whisker pole of length 1.1J, as advised by a website, and it proved perfect.
  2. #12
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    11,020
    Force4 do a cheap one. The one that they advertise is 22mm but they also do a larger one which they have to order in.
    I used the larger ones to make my wisker pole (from a wind surfer mast). I cut some 4 or 5 inch lengths and reduced their diameter to use as shims to mate the piston ends to the pole.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  3. #13
    Join Date
    Sep 2009
    Posts
    488
    I found ,with a 3000 long FG windsurf wave mast section ,that the £13 selden mast composite piston fitting ( as Force 4) is not man enough to deal with the occasional but extremely high leverage forces that you get when manipulating the sail and pole as the wind shifts etc. Shying away from the extremely expensive metal ends,before proving the arrangement, I tried two of these composite jobs and each snapped in the same place when jammed on the mast hoop.So I currently have a strong cord with a large snap hook and this allows the pole to 'float' around the hoop without jamming.
    I used a 100mm softwood insert jammed and coated with resin to mount the original test fittings and that has given a good point for fixing.
    Because of these occasional high forces and the fragility of carbon fibre I suggest that you must either use a proprietary end that is solidly resined into place or that you introduce a shouldered insert extension in another material that carries a fitting and so keeps the carbon away from the mast.You might look at a mast extension as a basis for this.I have one that is 45 o/d.
    The actual pole works a treat,using the spin. pole hoist attached to the outer end.
  4. #14
    Join Date
    Sep 2001
    Posts
    11,020
    Quote Originally Posted by bluerm166 View Post
    The mast hoop might be the issue. I use SS eyes each side of the mast and had no problems.
    MontyMariner.co.uk
  5. #15
    Join Date
    Sep 2009
    Posts
    488
    Yes agreed,and obviously the small composite selden fitting has too small a 'jaw' and is not meant for that kind of duty.
    But the benefits of the pole,especially the useful ability to furl the jib easily with it in place mean it's worth upgrading the inboard end.
  6. #16
    Join Date
    Aug 2016
    Norwich, UK
    Posts
    190
    Quote Originally Posted by dunedin View Post
    Interesting. Did the pole split at a screw hole or simply break without any existing point of weakness?
    What size of boat? And what length of pole?
    I would have thought a windsurf mast should be quite strong
    There were no obvious signs of weekness when I was running it.
    My genoa is a medium to heavy material at 7.5oz and is 36m2. The pole would bend a good 20 degrees under compression. I just think the thin end that attached to the genoa was too small. It tapers massively from the rear to the front. The fitting was torn out and the tail end of the fitting is what probably caused the damage in the photo.
    As I said I'll just try again with a shorter piece. It is 4.6m long, so I'll cut 20cm off the end.
  7. #17
    Join Date
    Feb 2004
    Boat (500m E of) the Clyde
    Posts
    4,554
    Quote Originally Posted by Mikedefieslife View Post
    Interesting, thanks. Initially I was not thinking of going anywhere near 4.6m, but probably just start with the lower mast section only at 2.6m. This is in fact only about 0.65 of J, but from some geometry and mock ups (using a boat hook) I think this should be plenty to stabilise a narrow blade jib (not intended for trade wind sailing!)
  8. #18
    Join Date
    Aug 2016
    Norwich, UK
    Posts
    190
    Yeah 4.6m is excessive, but the foot of my genoa is huge due to the aft set mast.
    At 2.6m you shouldn't have any problems. Mine is actually two pieces that slot together. I imagine that the base piece is close to 2.6m on its own, and it is very solid.
  9. #19
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    7,785
    Carbon is not the correct material if using a windsurf mast. Carbon masts are very strong in compression & bending. But only when these forces are applied in the correct manner. Where the boom goes they often need a sleeve & at the foot the coupling is a proper fit & applies the force in the designed manner.
    If one drops a carbon mast ( As I did once) it can easily shatter. If one were to compress the round end across its circumference so it forms an oval it will quickly distort & then form longitudinal cracks. If the end fitting were to jam on the spinnaker ring, possibly because it was not the correct size, it will apply high leverage to the end & the carbon will split a short length from the tube.
    A GRP mast is far stronger in these applications. (Better still a GRP wave mast)Carbon is used in windsurfers for weight & recovery when bending. Same in my dinghy mast. In a gust it bends quickly releasing wind from the sail but recovers fast.That does not mean that it will make a good spinnaker boom if not specifically made for the job
    It is all down to the fact that my wife does not understand me !!
  10. #20
    Join Date
    May 2001
    Posts
    14,081
    To prevent the inserted fitting from gouging its way out through the side of the tube (the rectangular slot in your photo) I would try to reinforce by building a collar around (1) the end of the tube and (2) in line with where the fitting ends when fully inserted. I would build the two collars with epoxy resin reinforced not with carbon but with glass rovings wound around the tube, building up as necessary and tapering to avoid drastic changes in strength (hard spots).
    Should we paint what is on a face, what is inside it, or what is behind it?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
