Results 1 to 5 of 5
Thread: 100mm Gauges
  1. #1
    Join Date
    Feb 2016
    Posts
    158
    Default 100mm Gauges
    Hi Guys
    It appears that 100mm gauges are no longer in vogue!
    My twin Cummins 6BTA set up has 2 tachourmeters where the hour meters (mechanical) have stopped working - I have found multiple different gauges that will do the job including VDO - but non of them are 100mm - they are all 85mm - am i missing something? Is there any reducing rings that anyone knows of?
    I dont fancy making a whole new front plate up x2 or buying 2x new instrument panels!
    Steve
  2. #2
    Join Date
    Nov 2002
    Colwell Bay
    Posts
    5,217
    Default Re: 100mm Gauges
    Quote Originally Posted by 5teve View Post
    Hi Guys
    Steve
    I found the same thing when I changed from minigen to alternator sense tachos when i re-powered.
    I found some at http://www.seahorsepower.co.uk/
    As an interim I bought a pair of 85mm ones from Funreaux Riddall, I might be able to dig them out and sell cheap if of any use.
    I do have a pair of minigen ones that work too.
  3. #3
    Join Date
    Feb 2016
    Posts
    158
    Thank Ben
    Glad i'm not the only one... As im in Aus - probably not the easiest place to send - but appreciate the offer.. I should have mentioned that the tachos are Mag pickup and with the built in hour meters - which then makes it harder still.
    I'm either going to have to get some reducer rings - or make a whole new panel up.. I do have some nice carbon fibre to do this with though or I could get some plates engraved and paint filled to replicate what I have now.
    I've just realised too that my gauges are this style (from a google search) - so may be a complete remake in the making!
    I'll carry on searching for a solution
    Steve
  4. #4
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    14,554
    It may be easier to get a new panel made locally and replace all of your old gauges with WEMA or similar (https://wema.co.uk/collections/marine?page=2). I see they're doing free worldwide postage in Oct.
  5. #5
    Join Date
    Feb 2016
    Posts
    158
    Thanks Pete
    I can get Wema and others pretty well priced over here but will check the worldwide shipping out. I can make the panel (time is my issue) and a new layout, gauges and connections would probably help quite a bit! I have the fuel senders and gauges to replace anyway as one goes up as it empties and the other one goes the right way - but not accurate so was going to start again..
    Now just to try and identify what the panels are normally made out of!
    Steve
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
