Results 1 to 10 of 10
  1. #1
    Join Date
    Jun 2014
    Torquay, Devon
    Posts
    463
    Default Replacement props for Volvo Sterndrive
    Can anyone advise on how I could spec a correct replacement prop set for a DPS-M outdrive?
    I can't easily make out any numbers on the existing props whilst afloat, probably due to a few years of antifoul build up.
    I have emailed the importer with the HIN number, but they haven't responded so far.
    Can they be sized by taking certain measurements?
    If the only definite method is to remove antifoul and read the part number, can anyone tell me where I would find the part number on the prop so I know where to scrape?
    There is nothing half so much worth doing, as simply messing about in boats.
  2. #2
    Join Date
    Nov 2001
    scotland
    Posts
    2,959
    Default Re: Replacement props for Volvo Sterndrive
    Used to be on the boss between blades and the nut end after you remove the lock washer
    Could be either size or VP part number
    Last resort go to dealer with boat details would get in the ball park but not a cigar
  3. #3
    Join Date
    Nov 2009
    living in cheshire, boat in Anglesey
    Posts
    2,552
    No lock washers on the DP-SM; they used Nyloc nuts. The part number is on the outside of the hub . Standard props were stainless steel, in which case the props were "F" type ( F1 to F9 I think). Aluminium ones were also available("D" series ?)If you can only read the "F" number off one prop, no matter, the other one should have the same "F" number. Some American boat builders, Four Winns for example, have the information on the standard props fitted, year by year and engine by engine. In their case "customer service/ fast facts".
  4. #4
    Join Date
    Apr 2005
    UK & The Med
    Posts
    433
    If you are in Torquay then the European HQ for Michigan Marine is in Newton Abbot you can take your prop(s) there where they should be able to match it up.
    Pretty competitive prices no delivery may even to get a bit of discount
    http://www.mmp-i.com
    Back into boating Hip Hip Hooray............
  5. #5
    Join Date
    Jun 2014
    Torquay, Devon
    Posts
    463
    Thankyou for your comments so far gents.
    Michigan Marine was my backup plan, I live 10 minutes from them, so if no joy from the Volvo Penta dealers, or boat importers, I will remove the existing props and take the round to MM.
  6. #6
    Join Date
    Nov 2009
    Posts
    2,552
    Quote Originally Posted by sprocker View Post
    What did they find/ recommend.; did they measure anything or just scrape off the antifouling to read the VP numbers? II ask as i'm interested in the relationship between Volvo "F" numbers and the pitch; I read somewhere that F6 = 26" pitch etc
  7. #7
    Join Date
    Jun 2014
    Torquay, Devon
    Posts
    463
    Quote Originally Posted by GrahamHR View Post
    They only do A & B series, so couldn't help me on this occasion. The UK importers came good in the end though, and traced the correct prop size through the manufacturers from the hull number.
  8. #8
    Join Date
    Apr 2013
    Guernsey
    Posts
    409
    When it comes to VP props.
    I have used this with some success in the past when repowering with a KAD42.
    http://www.pentamarine.co.th/pdf/propellers.pdf
    Glad that you managed to solve your problem through the dealer.
  9. #9
    Join Date
    Mar 2013
    boat conwy
    Posts
    2,535
    Quote Originally Posted by Dill et Bound View Post
    now he has found his props ,just wanted to say how are you dill
  10. #10
    Join Date
    Apr 2013
    Guernsey
    Posts
    409
    Still around mate... PM... Sent....
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
