Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Join Date
    Oct 2017
    solent
    Posts
    971
    Default Re: SORRY, another dumb question. Toilet
    Quote Originally Posted by John the kiwi View Post
    I dont really understand your objection to the holding tank concept?
    Tanks are cheap enough and easy enough to maintain. Would seem to me to be better than having two separate systems. After all the biggest disadvantage i can see in pump out toilet, with or without a holding tank is the through hulls and sea cocks and you have decided to have those anyway.
    By having a portapotti you are just buying a different sort of holding tank!
    I have a porta-potti on my boat and its perfectly usable, and as someone said, the thought of emptying is worse than the actual doing, thanks to those lovely chemicals.
    If i had room though, i would fit a manual toilet and holding tank and ditch the portapotti altogether.
    Would you rather carry a 15 litre tank of poo 200 metres or just open a valve?
    Just to be clear, I dont think I have, the plumbing and seacocks for the loo are already there, just no toilet. So my idea was just to stick one in and use it. As for a holding tank, it's only 24ft boat so I discounted that.
    Love the bucket comments, that is our current method in the 18footer ;-)
    We will be doing more than daysailing in the trident, especially with the luxury of an installed galley and running water. And a cabin big enough to exist in for ore than 30 seconds. Daysailing will still be the main activity though
  2. #22
    Join Date
    Nov 2011
    Nelson New Zealand
    Posts
    481
    Ah well i do understand.
    My boat is only 26 ft - with a stretchy tape. So space is at a premium.
    I have to say that the portapotti option has been a good solution and as said, why have duplicate systems?
    I have a thetford 20 litre jobby, (pun intended!). I have a small ratchet tie down strap that just goes over the lower tank and then i install the upper part.
    This makes it immobile and secure under all conditions. No holes in the hull. Whats not to like really?
    Aiming to live forever or die in the attempt!
  3. #23
    Join Date
    Mar 2002
    Greenwich
    Posts
    5,676
    The smell and having to empty it (ugh) compared to just flushing with saltwater.
    I've 11 holes in the hull so far and about to get 2 more with keel cooled fridge so I guess I have a more relaxed attitude to seacocks compared to blue poo.
  4. #24
    Join Date
    Aug 2003
    Colchester, Essex
    Posts
    4,564
    Someone earlier mentioned "the right hose" Last year I replaced the existing 2005 Jabsco with a Twist 'n' Lock, but more to the point used the expensive Vetus Sanitation hose. Well, what a revelation, although the hose was nearly as expensive as the bog, it was SOOOOOO worth it. On the previous install (when I was younger and fitter) I spent over half a day trying to get the outlet hose on. The Vetus stuff slipped on easily, and was watertight from day one... Well worth the cost IMHO
    Larry Botheras
    Colvic Victor 35 "Gladys"
  5. #25
    Join Date
    Jul 2012
    Riyadh, Saudi Arabia
    Posts
    705
    In your Trident you’ll need a Jabsco small head, a vent to fit the soil pipe and the white sanitary pipes to fit the in and out connections. Also, get good stainless jubilee clips (2 to a joint).
    When you come to fit the hoses to the seacocks you will also need a wooden hull plug and heat gun. PM me and I’ll tell you how the pro’s do it. (I know because one told me!)
  6. #26
    Join Date
    Oct 2017
    solent
    Posts
    971
    if the sea cocks were not already there I wouldn't have bothered with it, and stuck with a bucket, and a portapotty for special occasions, lol. It just seems a good way to make the seacocks safe, and the boat more complete.
  7. #27
    Join Date
    Oct 2010
    Posts
    468
    Built my own composting head for under $50.Love it.
    Search airhead.com, or natures head ,or sea head.
  8. #28
    Join Date
    May 2016
    Suffolk
    Posts
    4,752
    Quote Originally Posted by langstonelayabout View Post
    In your Trident you’ll need a Jabsco small head, a vent to fit the soil pipe and the white sanitary pipes to fit the in and out connections. Also, get good stainless jubilee clips (2 to a joint).)
    Wish i'd thought of that
    Rainbow Marine.
    www.rainbowmarine.co.uk
  9. #29
    Join Date
    Jul 2012
    Posts
    705
    Quote Originally Posted by PaulRainbow View Post
    You did. I just said it again.
  10. #30
    Join Date
    Sep 2013
    Posts
    159
    I would recommend a Lavac. Minimum of moving parts.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
