Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jan 2010
    Portsmouth
    Posts
    556
    Default Recommend an LPG 12 Volt GasAlarm
    Please ...any suggestions?
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    40,667
    Default Re: Recommend an LPG 12 Volt GasAlarm
    Quote Originally Posted by paella View Post
    Basic.. Nasa... http://www.nasamarine.com/product/gas-monitor/
    Well known...Pilot ... multiple sensor versions ... can also control other equipment eg gas shut off valve. https://www.envinsci.co.uk/envin-shop/
    Professional standard ...... Nereus ,,,,,,, sensors are water resistant http://www.nereusalarms.co.uk/
  3. #3
    Join Date
    Jan 2010
    Portsmouth
    Posts
    556
    Quote Originally Posted by VicS View Post
    Thank you
  4. #4
    Join Date
    Dec 2012
    Med for the summer, Caribbean for the winter
    Posts
    52
    Not sure exactly how suitable this would be however it is cheap and may be worth a punt
    https://www.ebay.co.uk/itm/12V-Combu...8AAOSw-3FZIsF8
  5. #5
    Join Date
    Jan 2016
    Ipswich, Suffolk
    Posts
    485
    I tend to fit the BEP models as standard. Either with or without solenoid control.
    Electrics & electronics Suffolk & Southwold Boatyard
    Custom Panels + Eberspacher/Webasto
  6. #6
    Join Date
    May 2016
    Suffolk
    Posts
    4,757
    Quote Originally Posted by Besonders View Post
    Sorry, but totally useless on a boat. LPG is heavier than air and will collect in the bilges, you therefore need a sensor with a remote probe.
    Rainbow Marine.
    www.rainbowmarine.co.uk
  7. #7
    Join Date
    Dec 2012
    Posts
    52
    Quote Originally Posted by PaulRainbow View Post
    Fair point, unless of course it is located within the bilge perhaps underneath the cooker
  8. #8
    Join Date
    Oct 2010
    Swing mooring Faro
    Posts
    5,431
    How much confidence do people have with gas detectors? We have the Pilot one with the sensor just under the sole board by the galley and it tests OK on its self test but wonder how reliable this is. Do wonder some times whether to blow some butane at it (unlit blowlamp or lighter) as a double check. Any thoughts?
  9. #9
    Join Date
    Jan 2016
    Ipswich, Suffolk
    Posts
    485
    That's basically the done thing in commercial testing along with smoke heads using canned smoke, heat sensors using a hot thing and float switches using a finger.
    When I fitted mine, just out of curiosity I did wave the sensor around the hob which was not lit and it did spark into life within 30 seconds or so.
    Obviously the skill here is determining which part of the boat will fill up with gas first. Manufacturers suggest in the bilge normally being the lowest point. I feared that for the time it would take for the gas to get from the closest gas union which is inside a kitchen cupboard, it was better to mount in the bottom of the kitchen cupboard with the only gas joint on the boat. There are no other joins from here until it gets to the gas locker in the lazarette. Theory is, the bottom of the cupboard would fill up before leaking into the bilge. However this is my decision to ignore the manufacturers instructions and I wouldn't recommend you did it.
    Quote Originally Posted by GrahamM376 View Post
  10. #10
    Join Date
    Jan 2005
    Me Edinburgh, boat JWD
    Posts
    4,638
    The sensors do not last forever, and a considerably shorter time if they get wet. NASA supply replacement sensors as a plug-in pcb at a reasonable price. Do check the availability of spares for your chosen model.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
