Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Join Date
    Dec 2003
    Posts
    1,577
    Default Re: Recommend an LPG 12 Volt GasAlarm
    If you can wait until about February when I get back to my boat, I will be replacing my NASA unit with the BEP unit - so my NASA unit (and spare sensor) will be for sale.
    I'd miss my compost heap
  2. #12
    Join Date
    Jun 2001
    Oban
    Posts
    648
    There was this thread http://www.ybw.com/forums/showthread...3-Lpg-detector last week.
    Derek
  3. #13
    Join Date
    Jan 2010
    Portsmouth
    Posts
    616
    Just a couple of quick questions. I assume these are not wireless devices i.e that the remote sensors will be wired and secondly is it normal practice to wire these direct to the battery?
  4. #14
    Join Date
    Jan 2016
    Ipswich & Southwold
    Posts
    853
    They are a wired sensor and then the head unit on all our commercial stuff and most pleasure boat stuff is wired to a permenant live (to the battery so to speak). Sometimes owners like them switched but on startup they usually go through an annoying loud beeping self setup/test function.
    Quote Originally Posted by paella View Post
    Electrics & electronics Suffolk & Southwold Boatyard
    Custom Panels + Eberspacher/Webasto
  5. #15
    Join Date
    Oct 2010
    Swing mooring Faro
    Posts
    5,530
    Quote Originally Posted by matthewriches View Post
    They should be wired direct to a permanent live and always on so if there's a leak, they warn you before you switch anything on. Just the act of switching something can ignite the gas
  6. #16
    Join Date
    Jan 2007
    Greece
    Posts
    1,147
    I had a Neres single sensor alarm on my old boat and it went off twice when gas leaked into the cabin due to a fautly bottle valve. On my present boat I have a Nereus combined gas and CO alarm. I also drives a solenoid to cut the gas off at the bottlle. LPG sensor is mounted at cabin sole level, CO sensor at head level when seated. Never gone off but tests as OK.
    I'm a big fan of Nereus as the sensors still work when they have got wet. I don't plan to immerse the sensor but reassuring to know it will be OK if it does get wey
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
