Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    12,451
    Default Re: NMEA in - Can 2 devices supply one input
    Quote Originally Posted by BelleSerene View Post
    It's a messy solution I'm afraid. Half the time the switch will be selecting the wrong chartplotter, and the GPS won't have lat/long or time, which is inconvenient and in the case of needing to do a DSC, downright dangerous.
    Sure is. The one reason for me getting a DSC radio with a GPS receiver was I did not have to worry about hitting the wee red button if ever I needed to.
    Cynical Scots engineer.
  2. #12
    Join Date
    Jan 2003
    Clyde
    Posts
    6,858
    Quote Originally Posted by Sandy View Post
    No need to worry, If your DSC radio is not getting any NMEA input it will soon tell you.
  3. #13
    Join Date
    Jan 2003
    Clyde
    Posts
    6,858
    Quote Originally Posted by Rogershaw View Post
    2 way toggle double pole double through change over.
    P1 /2 would connect to the radio and the T1/2 would connect to each of the 2 GPS devices.
    That's the idea but you don't even need a double pole. Single switched nmea feed and common earth would be fine.
  4. #14
    Join Date
    Nov 2001
    Me: Johannesburg South Africa Yacht: Durban East Coast Africa
    Posts
    6,208
    Quote Originally Posted by Spyro View Post
    In most cases yes but NMEA is realy RS 422 differential and not knowing the exact spec of the 2 output devices switching both wires is safer in my view and the cost difference is not much anyway.
    Life is too short not to have a sea view
    Distantshaws tinyurl.com/yclt6l68
  5. #15
    Join Date
    May 2001
    Posts
    20,464
    Most if not all NMEA devices I have seen use a single wire to transmit / receive and a common signal ground.
  6. #16
    Join Date
    Mar 2005
    Hants/Lozère
    Posts
    4,028
    Quote Originally Posted by bedouin View Post
    I'm just about to update a bit and my Airmar H2183 heading sensor, Vesper AIS XB8000 transponder, SH GX2000 radio and Raymarine SPX30 autopilot ALL have two-wire differential NMEA 0183 connections.
  7. #17
    Join Date
    May 2001
    Posts
    20,464
    Quote Originally Posted by Hoolie View Post
    Okay - I'll rephrase that - almost all Garmin devices use a single wire
  8. #18
    Join Date
    Nov 2001
    Posts
    6,208
    That's because Garmin don't comply completely with NMEA 0183 at the electrical level and some of their messages also are specific to Garmin.
    All my old SIMRAD comply but I can make then single wire to connect to non complement like my RS232 to USB to connect into my computer running OpenCPN.
  9. #19
    Join Date
    Aug 2003
    Colchester, Essex
    Posts
    4,706
    I have this aboard with a Garmin 152 backing up my GPSMAP 751. It only works if you remove the data/power plug from the back of the plotter/GPS
    Larry Botheras
    Colvic Victor 35 "Gladys"
  10. #20
    Join Date
    Nov 2009
    Southampton
    Posts
    34,362
    where are the plotters getting their lat/long and time data from anyway? - presumably from a 4800 baud NMEA 0183 network
    No, they each have their own built-in GPS receiver.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
