Results 1 to 4 of 4
Thread: Raw water pump
  1. #1
    Join Date
    Dec 2017
    Posts
    3
    Default Raw water pump
    My boat came with no water pump as it was removed, buying new would cost me 500 if I add another 700 I could get a new engine! The question is, I got two jabsco water pumps which can pump more water through than the original pump can! Bit I made adapter to make sure my pumps are working and pumping, bit they pump through more water than original should, can this cause any problem to my engine ? Only people who understand are welcome to reply! Pls no guesses! Thanks
  2. #2
    Join Date
    May 2005
    up on the moors.
    Posts
    31,762
    Default Re: Raw water pump
    The problem might be that the engine is running at too low a temperature, and that leads to poor combustion and wear.
    Are you pumping sea water with pumps designed for fresh ? I am not sure that Jabsco FW pumps are designed for continuous operation e.g. for an hour or two.
    What make and model is the engine please ?
    I think, therefore I am. I am, therefore I sail.
  3. #3
    Join Date
    Jan 2016
    Ipswich, Suffolk
    Posts
    480
    Maybe pop a post in the practical forum, more people are likely to see it there
    Electrics & electronics Suffolk & Southwold Boatyard
    Custom Panels + Eberspacher/Webasto
  4. #4
    Join Date
    Jun 2011
    Suffolk
    Posts
    3,335
    Oddly enough a ‘different’ poster did just that yesterday.
    http://www.ybw.com/forums/showthread...rpump-question
    Be nice.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
