The best explanation I have seen uses the unpowered Gyroscope/Gyrocopter analogy.A Gyroscope with a locked blade will plummet to earth:a Gyroscope with its blade rotating will glide to earth.It is clear that the rotation increases resistance. From all points of view,the answer must be to lock your prop in gear,or by other means.
Results 11 to 18 of 18
Thread: Propeller rotation under sail?
30-03-01, 15:34 #11Guest
Re: Propeller rotation under sail?
31-03-01, 01:28 #12Guest
Doesn't anyone use it for turning an alternator anymore.....or did I miss something???
02-04-01, 09:47 #13Guest
According to practical sailor which did some extensive testing in the US there is less drag with a rotating prop.I have a Hurth gearbox and except for the noise its just fine.
02-04-01, 18:12 #14Guest
and the noise means WEAR! bearings shafts etc god knows what its doing to a hydraulic box !
02-04-01, 18:16 #15Guest
Now that WOULD cause drag !
04-04-01, 20:55 #16Guest
shaft gen
My friends used the shaftgen om transatlantic cruise om PRM transmission.
When the velocity is so high that wavemaking drag is is significant, the generator will not slow the boat much.
14-04-01, 05:32 #17Guest
Propeller rotation Hurth!!!
Don't do it!!!!!!
I have just had to buy a new Hurth gearbox! It was only a little more expensive than refurbishing the old one. 2500 Oz dollars! The plates wore out because the previous owner let the prop spin.
The new gearboz works wonderfully!
Fair Winds Captain Mudbank
14-04-01, 05:42 #18Guest
Ah yes, mate....BUT
A gyrocopter with its blade rotating to cause LIFT and DRAG will slowly descend. However think about the blade spinning the other direction, driven by the medium through which it is travelling, as is a freewheeling boat prop. I suggest you go up in a helicopter and ask the pilot to try it. It is called "autorotation". Now kids, don't try this at home!! Captain Mudbank
Bookmarks
