Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Jan 2018
    Posts
    2
    Default best airless paint sprayer
    Hi everyone
    I am looking for a best airless paint sprayer for my boat and basic outdoor jobs. My budget is no more than 500$, Can anyone help me suggesting best recommend paint sprayer for me?
    Thanks, best regards
  2. #2
    Join Date
    Dec 2007
    Near Burton-on-Trent
    Posts
    1,968
    Default Re: best airless paint sprayer
    You could get a small garage compressor and a DeVilbis gun (or copy) for that money..
    You could blow your tyres up too!
    Is space an issue? The buzzing hand jobs (!) were pretty poor, Google LPHV
  3. #3
    Join Date
    Oct 2010
    Swing mooring Faro
    Posts
    5,527
    As an alternative to airless or high pressure, the Fuji HVLP (high volume low pressure) systems seem to be getting good reviews, one example here - https://www.axminster.co.uk/fuji-sem...-system-501285 - as usual there are YouTube demo videos around.
  4. #4
    Join Date
    Jun 2005
    Posts
    21,031
    Wagner do a DIY airless unit, they do pro stuff so should be quite good
    If I'd wanted to live in a Banana Republic I'd have gone to South America.
  5. #5
    Join Date
    Nov 2009
    UK
    Posts
    2,041
    I've just bought a Wagner Air;ess Sprayer Plus from Screwfix and some larger filters and nozzles from ebay. I plan to spray the antifouling later this month (too old to paint a 36' long keeled steel yacht by hand). The youtube videos of it in use, including antifouling a fin keel yacht & spraying a car, made it look reassuringly easy, with no mess and minimal masking needed.
    I expect the AF (semi hard 45% copper) will need to be diluted 10% but the application is so quick that several coats would not be a problem in a weekend. Just need some calm, dry weather.
  6. #6
    Join Date
    Mar 2017
    Me; Nth County Dublin, Boat;Malahide
    Posts
    627
    Quote Originally Posted by NickRobinson View Post
    The USP of airless spray is that there is considerably less overspray generated, a big advantage when working in a crowded boatyard or outdoors in the average suburban property.
  7. #7
    Join Date
    May 2001
    Larkhall, South Lanarkshire
    Posts
    332
    I personally wouldn't bother with trying to spray a boat. You can apply a thicker layer of paint and get as good a job just by using a brush without all the masking up and over spray problems.
    as an example here is a 38 footer painted in epoxy with a brush. http://linnetwoods.com/marinezine/_images/aa_y_k_03.jpg
  8. #8
    Join Date
    Nov 2013
    Perth WA
    Posts
    1,727
    I'm particularly interested in this thread as I am trying to paint above the waterline of a 43 ft yacht I am building.
    The paint is two pot polyurethane. I tried to do a "roll and tip" on my own but that ended up as a disaster. I got my S-I-L to help with a second coat and got a better result but not too good.
    I do have a 15m≥ compressor but a fellow boatie says I should be using an airless spray gun and you can hire them. I wouldn't consider that as I think I would have to practice for a day or two on my back shed.
    Maybe I will have to buy one but I definitely do not want to overcapitalize.
    (Gee, I wouldn't want to get caught doing it because it is illegal to spray paint the polyurethane paint in an open area in Australia)
    Clive Cooper
  9. #9
    Join Date
    Nov 2013
    Perth WA
    Posts
    1,727
    Is it any wonder Trump is going off his brain about stealing intellectual property?
    (Sorry I had to get that off my chest)
  10. #10
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,223
    Quote Originally Posted by coopec View Post
    A couple re-gelcoated the topsides of a 38 ft Beneteau in our yard in Greece. At the same time they used two-pack PU for the cockpit. Having tried each product on the opposing surface they concluded that this was the optimum way. The gelcoat was applied by roller, one coat per day, any runs or bumps being easily flattened off before applying the next coat. Finally they flatted it with orbital sanding, then polished. Labour intensive method but relatively easy to do. The final results were superb.
    Gelcoat in the cockpit area was much more difficult, they found PU paint far easier to control.
    Answers to some technical queries at new website http://coxeng.co.uk
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
