Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Join Date
    Oct 2009
    Posts
    2,282
    Default Re: Asymmetric spinnaker or cruising chute?
    Again, thanks for everyone's input on here, this is all incredibly useful and I've learned a lot.
    I do wonder if I'm just over-thinking things here a bit, and perhaps what I want as a cruising man on my cruising boat is a cruising chute. I'd still go with the bowsprit, but if I'm honest perhaps as a dinghy man I hadn't realised about where all these A-sails sit in terms of wind strengths and angles and weights. If I'm honest I probably want the most versatile sail I can get, that I have the maximum opportunity of flying downwind on any given day, and be realistic that although a Bav32 is a step up from the Sabre in terms of performance, she's no race boat, and as soon as things get breezy-ish on a reach, white sail will probably be fine anyway, especially with that dumbass mainsheet arrangement.
    lw395 it certainly will not be some cross cut item, and as the loft building the sail will make it to measure including the bowsprit, perhaps if they can do something that is somewhere between a totally stable cruisey cruising chute and perhaps something a little more exciting and bigger, that will do the job, and as flaming points out, go and find a second hand race sail for a bit of a laugh with the lads in the light stuff...
    Bavaria 32 GBR4755L "Adastra"
    49er GBR340 "20KSB"/Fireball GBR14474 "Eleven Parsecs"
  2. #22
    Join Date
    Nov 2007
    Posts
    32,180
    Suspect you will find the mainsheet less of an issue once you have sailed the boat. However, if it is long enough you can take the tail back to the rear of the cockpit, leave the clutch open and fit a cleat for it on the outside of the coaming. That is what I did on my 37. Did not offer full control but made dumping easier on the rare occasion it was necessary. In fact I had cleats on both sides which I also used for cleating off the mainsail preventer.
  3. #23
    Join Date
    Dec 2010
    Posts
    8,505
    Quote Originally Posted by flaming View Post
    It's not normal to adjust the tack line in a dinghy. Anything fast enough to plane never eases the tack line.
    Thanks!
    Quote Originally Posted by Iain C View Post
    ...and as soon as things get breezy-ish on a reach, white sail will probably be fine anyway...
    Exactly my thinking. Considering how little wind is too much for my full white-sail area, I doubt the kite will ever see more than 10 knots...
    ...but there are also plenty of days when all the white sail isn't enough.
  4. #24
    Join Date
    Dec 2010
    Posts
    8,505
    Another thought...
    I've never paid much attention to the lightweight line inside the luff of my "screecher", which I bought before laying my hands on a more suitable sail. But the luff-line is clearly adjustable. Why?
    This sail has only 8ft of foot - so it doesn't need a bowsprit - but the luff-length is about 19ft, rather a lot for the 15ft 6inch height of my spinn halyard block. Can I tighten the luff-line to shorten the luff, so the head needn't be hoisted so high on the mast?
    I'm imagining - hoping - that the wrinkles which a shorter luff-line would induce, will spread themselves evenly up the height of the sail. If the luff line doesn't or can't enable this rather flat sail to assume a different shape, what does it do? How limited is its use?
    Below shows about the lowest point I can hoist the head to, without the whole flat sail bagging sideways. Sorry, those who've seen it all before. (And, if you've told me before and I've forgotten. )
  5. #25
    Join Date
    Oct 2009
    Posts
    2,282
    Guess you missed my little request to keep the thread on track here Mr Crane...
    However that sail is far too small for the boat. Don't bother faffing around with lines, just get a kite that fits the boat better.
    Oh, and after speaking again to my preferred loft, we're going for an all round sail, that's essentially just a slightly bigger cruising chute. After having taken some of the excellent advice on here, what I wanted was a downwind sail that was as versatile as possible and could be used over as wide a range of angles as possible, with perhaps a bit more emphasis on getting downhill rather than reaching. Full radial, dyneema lines, Maxilite 150 cloth. And the spawn of satan spinnaker snuffing system!
  6. #26
    Join Date
    Dec 2010
    Posts
    8,505
    Sorry for the drift. I thought the adjustable luff-line might be a way to change the sail's profile, thereby allowing some crossover between the sail-types which are the basis of this thread. I've also got a nice full-bellied asymm, just haven't finished the chute and sprit yet...and meanwhile, I was thinking of trying out the black kite this weekend. I was thinking it's too tall, more than too small.
  7. #27
    Join Date
    Jul 2012
    Riyadh, Saudi Arabia
    Posts
    1,176
    Quote Originally Posted by pagoda View Post
    Also bear in mind that the length of your bowsprit may or may not give enough clearances for an inside gybe. We have a Selden bowsprit and are safer with outside gybes..We also fly a code0, which avoids the problem entirely.
    Assuming the pole is 2' long and the luff isn't too tight it should be fine; I never had a problem when flying a 'small' 18 foot skiff asymmetric from the front of my similarly set up E-Boat.
  8. #28
    Join Date
    Jun 2005
    London
    Posts
    2,284
    Can someone explain terminology? I have what I was told is a cruising chute/gennaker. It is marked with tack, clew and head. A friend has what he calls an asymmetric. It is marked with head, port corner and starboard corner. He thinks that for a starboard tack the corner marked stbd takes the sheet and the corner marked port effectively becomes the tack. Is this correct? If it is, how does one gybe?
  9. #29
    Join Date
    Mar 2004
    Posts
    10,040
    Quote Originally Posted by tudorsailor View Post
    I don't think he has an Asymmetric....
    You never know, I might be right!
  10. #30
    Join Date
    Dec 2010
    Posts
    8,505
    Flaming is right, your friend has misunderstood the definition of 'asymmetric'. If it is necessary or possible to switch the tack and clew of the sail on alternate tacks, then the shape of the sail must necessarily be symmetrical.
    If he really does switch tack and clew on an asymmetric, for alternate tacks, I would pay to see footage of it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
