Page 81 of 127 FirstFirst ... 3171767778798081828384858691 ... LastLast
Results 801 to 810 of 1262
Thread: Steelboats
  1. #801
    Join Date
    Oct 2010
    Posts
    1,289
    Default Re: Steelboats
    [Quote]
    image: http://www.ybw.com/forums/images/ybw...quote_icon.png
    Quote Originally Posted by rotrax
    image: http://www.ybw.com/forums/images/ybw...post-right.png
    View Post
    Why dont we see these problems in the magnitude you encounter on this side of the pond Brent? Surprising when we have many, many more boats in use than BC.
    I am not suggesting for a moment they cant and dont happen, but you know loads of friends suffering these problems, every bay in BC is littered with holed GRP boats, all GRP boats in BC are only fit for " Marina Queens "
    __________________________________________________ ___________________________________
    Another attempt at a strawman argument., Give us the quote in which I said
    "Every bay in BC is littered with holed plastic boats ." I made no such comment .You just made it up so you would have something to argue against , liar.
    By far most plastic boats in BC live most of their lives as Marina queens, as they did in Auckland while I was there for nearly a year and a half.
    They seemed to do a hell of a lot of maintenance work on them, spending entire winters hauled out, considered standard proceedure there.
    __________________________________________________ ____________________________-
    Its different in the UK and Europe. The ones in trouble are made from a dense, heavy metal which is severely prone to corrosion near seawater.
    ":Severely prone" is total bull, if maintained properly , an hour or a two year, if painted well.
    95% of my epoxy is as good as when I put it on, over 34 years ago.
    Most of the boats suffering expensive or terminal problems are not made of wood, aluminium or GRP over here.
    I am an active member of 2 yacht/boat clubs, one in the UK, one in NZ. Total membership of boat owners around 300. IIRC-in the last two years, apart from improvements and routine maintenance:-
    One GibSea had a loose P bracket, one knocked a bit off his rudder sailing a 6 foot draught boat in 4 feet of water in Wellington Harbour trying an expensive short cut during an evening race, one had a shroud fail-it was 30 years old, so he changed the lot-one had a serious water leak from a hatch, again a 40 year old Houdini which required re-glazing by a specialist. Another GRP owner had a water leak from the toerail. Lifting and re-bedding the through deck stantion bases soon sorted that.
    Nigel Calder didn't do so well, bumping his rudder briefly, as reported in last months Sail magazine. One of mine pounded for 16 days in Baja surf with less damage. So much for your lie that "it doesn't happen on your side of the pond."
    Shroud failure has nothing to do with hull material.
    Aluminium hatches don't leak,if built well.
    Hal Roth mentioned dozens of to rail bolts leaking,on his stock plastic boat, something which doesn't happen on a welded steel bulwark.
    )_________________________________________________ _____________-
    No one currently has serious osmosis, but some have had treatment in the past, no one has a rotted core, or a problem with through hulls or mast supports.
    Don't believe that for a minute, given your lies I have pointed out so far.
    Lots of rotted out cores and osmosis around here, saying balsa ,and gel coat behaves differently over there is , obviously, yet another one of your many lies.
    Lots of talk about thru hull problems on many forums, and in magazines.
    So, that is my experience through knowing the gossip around 300 ish mostly GRP vessels in two clubs. Lets double the number of serious faults, as I might not be aware of some, and we get ten.
    Just with your friends you list eight.
    Read more at http://www.ybw.com/forums/showthread...msyLeXQWOer.99
    Far more that 8 boats with problems listed, both here, and on your side of the pond. Yet another transparent lie. Anyone surprised?
  2. #802
    Join Date
    Dec 2010
    South Oxfordshire, Gosport and Wellington New Zealand.
    Posts
    7,578
    [QUOTE=Brent Swain;6710324]
    Well-another load of BS. BS now means Brent Swain.
    What about the " Advice on here caused him to spend 14 years doing a boat "
    Either I or you are telling lies, Brent.
    I think the readers of these pages are experienced enough to make their minds up on that one Brent..............................
    PS :-Look at your post 734 Brent " The south BC coast is littered with plastic hulls with holes in them. "
    It took a Straw Man about two minutes to find that.
    Apology Brent-it would be nice, but I have little hope!
  3. #803
    Join Date
    Oct 2010
    Posts
    1,289
    I first met Evan Shaler in the summer of 1983, while building a 31. He had talked to the Pardeys , and had spent ten months building a male mold for a 26 ft Bristol channel cutter . He priced the fibreglassing materials , for hull and decks, and had been quoted $12 K.
    Then he watched me build the hull, decks, cabin, cockpit, keels, rudder and skeg for a 31 for $3500, in three weeks.He tried to sell his mold, but no one wanted it. So he abandoned it ,and built one of my 31s for a fraction the time and money. He has built several dozen for others since.
    The 31 sailed south to Panama, several seasons in the west indies,and on to England .One of the owners visited her old job ,and saw that the guy who had advised her to buy a plastic boat, who was still working and making payments on his, having gone nowhere.
    The last quote we got ,a couple of years ago, for the steel for a 36, shell, was around $9K. It has remained steady or slightly less since then. You don't buy much fibreglassing material for that little.
  4. #804
    Join Date
    Oct 2010
    Posts
    1,289
    [QUOTE=rotrax;6710327]
    Quote Originally Posted by Brent Swain View Post
    The kind of advice given here, to buy an old plastic boat , to save time and money , is what I am referring to.
    Sure didn't work out so well in that regard, for him.
  5. #805
    Join Date
    Dec 2010
    Posts
    7,578
    [QUOTE=Brent Swain;6710330]
    Quote Originally Posted by rotrax View Post
    Again Brent, total BS.
    Users of this forum dont need you giving unwanted advice. The advice I have most often seen on here is something like " For that money you could end up with a time and money pit. Buy something ready to use. " Please link where the advice you say has been given, because its a new one on me.
    I remember a mouthy bloke like you being told by a fellow motorbike racer :- " You can be my sexual adviser. When I want your banned four letter word begining with F advice, I shall ask for it! "
  6. #806
    Join Date
    Nov 2008
    Posts
    6,779
    [QUOTE=rotrax;6710332]
    Do you really think that your post (above) makes any useful contribution to the sum of knowledge about steel boats?
    (I don't actually require an answer).
  7. #807
    Join Date
    May 2005
    Posts
    7,168
    I don't believe you. Lying on a beach, maybe. But not 16 days of "pounding in Baja surf".
    I know of a lightweight GRP race boat that was pulled off after a week of pounding in the Brazilian (yes, Atlantic) surf. With no damage.
  8. #808
    Join Date
    Dec 2010
    Posts
    7,578
    [QUOTE=NormanS;6710400]
    You are quite right-it offers nothing at all regarding steel boats.
    It was born out of total frustration with BS.
    I do own a modest steel yacht-I was replacing the hatch yesterday after fettling the rusty mounting.
    When its gone, I wont be having another.......................................
  9. #809
    Join Date
    Dec 2003
    Posts
    5,278
    What on earth is going on with the quoting system
  10. #810
    Join Date
    Dec 2007
    S.W. France
    Posts
    7,272
    Quote Originally Posted by dom View Post
    Works for most of us. Just not BS.
    Think I have seen enough of this going round and round to no point. Should spend more time in the shed, where I am building a wooden boat
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
