Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Join Date
    Oct 2001
    River Orwell,East Coast
    Posts
    1,627
    Default Re: Is this stainless steel anchor chain suitable?
    Eye Co near to Felixstowe do 6mm G40 chain. I use 6mm on my Moody 31 with no problems.
    They trade as boatgeardirect.co.uk online
  2. #12
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,969
    Quote Originally Posted by GaryCottam View Post
    Hi Jonathan, Tecni state that the WLL is 625 kgs and the MBL is 2500 kg, wich is 4 x WLL
    The link says their chain is to DIN 766, which is a dimensional standard. It should therefore fit the gypsy you have linked to. The strength equates to Grade 30, the minimum standard. I think this chain may be good enough but is not specifically intended for anchoring. Much European made stainless chain is made in Spain for the fishing industry. The suggested Grade 70 6 mm would be more reliable.
    Answers to some technical queries at new website http://coxeng.co.uk
  3. #13
    Join Date
    May 2014
    March
    Posts
    572
    Thanks for all the advice, much appreciated.
    I'll try seeing if I can get a cone to stop the piling, if that works great, if not I'll go fo the better 6mm grade Vyv suggests.
    Thanks again.
    1976 Westerly Centaur, GEMINI
  4. #14
    Join Date
    Nov 2009
    Southampton
    Posts
    35,600
    Quote Originally Posted by Tranona View Post
    SS chain is approx 3 times the price of galvanised and simply not worth it.
    There is little you can do about chain piling up
    I don't have personal experience in an anchor locker, but stainless chain is more slippery than galvanised and a heap of it on a workshop floor does sit slightly flatter. It's reputed to reduce the piling effect somewhat.
    I note that although there's a radio button for "7mm DIN766" on the Jimmy Green page, there's no such entry in the table below. I would double-check that the 7mm windlass they're offering is indeed for DIN766 chain (or will fit it well enough if not specifically made for it).
  5. #15
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    213
    Thanks again.
    How did you get on with the cone which you were going to try? I also have a piling chain which I have to reach down and knock over several times each time the chain is wound in so am looking for a solution.
  6. #16
    Join Date
    Mar 2017
    Me; Nth County Dublin, Boat;Malahide
    Posts
    841
    The DIN dimensions of the chain and gypsy have already been addressed. The specs on the web page mention the word '"marine" twice and also include the standard "316", so the chain should be perfectly serviceable, if EU manufactured.
    It has just occurred to me that we may no longer be able to use the term "gypsy", as Facebook has ruled that it is a term of abuse!😩
  7. #17
    Join Date
    May 2014
    March
    Posts
    572
    Quote Originally Posted by Cardinal View Post
    I didn't get that far down my list of possible solutions, I altered the where the chain drops down in to the locker, where it is deeper and the chain does not hit the top, and so far no jams.
    The downside is, I now have a pipe in the middle of the v-berth, this has to be moved, whenever the v-berth is used and/or before/after anchoring. An inconvenience but one I'm prepared to accept so tyat I can raise/lower the anchor from the cockpit reliably. But, I appreciate this m,ay not be for everyone.
    Pictures here: https://www.westerly-centaur.co.uk/n...chain-solution
  8. #18
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    20,304
    Does the chain run down inside the pipe? If so, how to you remove the pipe?
    Richard
  9. #19
    Join Date
    May 2014
    March
    Posts
    572
    Quote Originally Posted by RichardS View Post
    Richard
    Hi Richard,
    Originally I didn't think that the pipe would be in the way, as I thought 2 people could be in the v-berth and sleep with their feet either side, that proved not to be the case.
    So I cut the 2 vertical pieces of pipe and sheeved them with 2 pieces of silicone pipe, when at anchor I can then remove the pipe/chain and hang out of the way. I don't have a picture of this to hand.
    So far it seems to work quite well.
  10. #20
    Join Date
    Jul 2006
    Emsworth Hants
    Posts
    12,573
    A boat anchored off the Chaguaramas in Trindad had stainless chain he was anchored for over a year with the chain rubbing over the sand, this caused crevice corrosion and it broke. I have never heard of galvanised chain breaking.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
