Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Join Date
    Jun 2001
    Guernsey, Channel Islands
    Posts
    3,184
    Default Re: American electrical advice (shore power)
    Quote Originally Posted by RobWales View Post
    Hi all,
    Should I modify my supply lead by removing the split to two plugs and use just the one as I'm not happy with a live supply being hung up under my gunwhale....?
    Many thanks in advance.
    Rob.
    Hi Rob, You really shouldn't have two plugs on the end of your shore power lead. First, as you say, it's a hazard to have a live plug hanging loose, but often, shore power suppliers are fed from different phases. So not surprised it causes problems.
    These are the voyages of Play d'eau....www.playdeau.com
  2. #12
    Join Date
    Sep 2005
    Brighton/Antibes
    Posts
    8,181
    Quote Originally Posted by GSL View Post
    The very best and easiest way to fix this is to fit a Mastervolt Soft Start in the line as it comes into the boat, before the transformers. The best 240 you will spend on the boat.
    I speak from experience on this.
    Graham
    This sounds like the right advice. At a guess the OP has two isolation step-up transformers, one for each inlet, and the simultaneous inrush current surge from both transformers is what's causing the supply to trip. It sounds like the inrush from one transformer alone is below the rating of the trip on the shorepower supply.
  3. #13
    Join Date
    Feb 2015
    Conwy
    Posts
    2,621
    Could it also have something to do with the American 220V system is max rated at 50 Amps as opposed to our 16 / 32 Amp? (2 x 110V @25A with common neutral)
  4. #14
    Join Date
    Sep 2005
    Brighton/Antibes
    Posts
    8,181
    Quote Originally Posted by BruceK View Post
    I might be missing your point a bit here (if so - sorry) but how is there a common neutral with a twin step-up transformer installation?
  5. #15
    Join Date
    Feb 2015
    Conwy
    Posts
    2,621
    Hi Jimmy. It so happens that a week or two ago a similar fault was being discussed on the FB Trawler Living and Cruising group. It piqued my interest as I also have an American boat albeit now converted to EU standards. The fault turned out to be the common neutral, but what fascinated me was their approach to220V. You need to be a member but here is the link:
    https://www.facebook.com/groups/traw...=group_comment
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
