Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Join Date
    Jun 2018
    Posts
    12
    Default Re: Using antifreez to flush and clean outboard water jackets
    Okay, so its been a few days since my last post, ran the engine in some descaler cleaner, let it sit for a couple of days, today flushed it out with just straight clean cool water, pee hole stream still seems abit weak for my liking, not sure what is a normal stream as I have always had 100+ HP outboard engines with bigger tel tails. Now, im thinking, when I run the engine, im putting it a large bucket (not ear muffs), the water is just going over the anti ventilation plate, the first plate on the outboard, I keep it topped off as its running, sometimes its just going under the plate, but im wondering is the lower unit being put in enough water? As I have read just becuase you cover the water intake screen doesnt mean you will get 100% water flow from the impella/Water pump. Right now Im not able to hook the engine up to a hose as there is a local hose pipe ban in my area and they wont let us use the comminuty hose becuase of a so called drought. Anyway, Should I try to get a taller bucket to put the engine in? ill be down to the boat in a weeks time. Im thinking ill just try it in a real world situation. But my question is how far should the water go up the lower unit to get a clear indication of water intake?
  2. #22
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    41,576
    Quote Originally Posted by Horizons View Post
    Okay,...........................
    Ordinary buckets are unlikely to be large enough. You need to ensure that the water pump is covered .
    The turbulence caused by the exhaust is also likely to be a problem with such a small reservoir
    A dustbin or a wheelie bin would be better choices .... I use an old domestic cold water tank..
  3. #23
    Join Date
    Jun 2018
    Posts
    12
    Quote Originally Posted by VicS View Post
    I did notice this was an issue, the water intake screen was exposed for a couple of sec once and a while
  4. #24
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    20,426
    See my website http://coxeng.co.uk/cruising/outboar...h-water-flush/ for a good way to flush small outboards using an old fender.
    Answers to some technical queries at new website http://coxeng.co.uk
  5. #25
    Join Date
    Jun 2018
    Posts
    12
    Nice website, thanks.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
