Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    143
    Default Volvo Pentagon 2003T Raw Water Pump
    I am keen to acquire a decent replacement for this which I understand is not the same as the non-turbo version.
  2. #2
    Join Date
    May 2007
    Itinerant. On an adventure!
    Posts
    2,704
    Default Re: Volvo Pentagon 2003T Raw Water Pump
    How bad can it be? Can be refurbed. Well, I did it on my 2003 without incident.
    Gwylan, a settee with a sail
  3. #3
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    143
    Agreed, but there was a rush on!
    Incidentally, how much welly is required to drive out the shaft once the pin has been removed from the engine end? I did not expect it to be so stiff and fear that the bearings may be damaged. did you just replace the water seal behind the impeller?
  4. #4
    Join Date
    May 2007
    Posts
    2,704
    Not too much and yes I "just" replaced the bearing. Drain the engine oil.
    Maybe there is some other problem if it is hard to remove.
    Once removed I used a bit of wood between the hammer and the end of the shaft whilst encouraging it all to come apart.
  5. #5
    Join Date
    Aug 2004
    Gosport
    Posts
    2,998
    Moody 31
  6. #6
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    143
    Thanks for that link. I have actually sourced a fresh pump via a VP agent, so the old one will become a spare once I refurbish it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
