Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Apr 2002
    Faversham
    Posts
    873
    Default Navionics app no longer shows depths
    I have been using Navionics on my iPad for about 3 years. Very happy with it but it has suddenly stopped showing depths
    Any ideas? I have uninstalled and reinstalled but that didnít help. My subscription is up to date.
    All ideas gratefully received
    Thank you
    Graham
  2. #2
    Join Date
    Apr 2002
    Faversham
    Posts
    873
    Default Re: Navionics app no longer shows depths
    I feared as much...
  3. #3
    Join Date
    Dec 2010
    Guernsey
    Posts
    356
    I canít help as youíve done the obvious thing of re-installing the app. I can only report that Navionics on my Hudl 2 has worked normally during the last few weeks when I used it extensively.
  4. #4
    Join Date
    Apr 2011
    Dublin and Alicante.
    Posts
    655
    No problema on my Android Samsung.
    Just to be clear however. regarding depth.
    I only see depth in two ways.
    Chart depth and in the auto route.
    Am I missing something?
    Just here for the Craic!
  5. #5
    Join Date
    May 2012
    Second Coast, Ross-shire, overlooking Gruinard Bay.
    Posts
    7,221
    Seems to be working OK on my laptop.
    Not sure if I took out a subscription and paid anything when I started using it in 2015.
    Perhaps time is running-out for me too.
    Good luck sorting-out the problem
    Kay Sarah Sarah
    57į51.42' N 5į29.44' W
  6. #6
    Join Date
    May 2016
    Suffolk
    Posts
    7,708
    Quote Originally Posted by gdallas View Post
    Any ideas? I have uninstalled and reinstalled but that didn’t help. My subscription is up to date.
    Thank you
    Graham
    Reinstalling may not reset options that you previously selected. Take a look at the settings in "map options" and "advanced map options". There are several options within those menus that affect depth display. If you're not sure which to change, reset them to defaults.
    Rainbow Marine.
    www.rainbowmarine.co.uk
  7. #7
    Join Date
    Sep 2007
    Largs
    Posts
    236
    Found this old thread whilst searching for the same problem as the OP had. I could not see any useful depth marks on the chart (plenty of contours, but no use without the depth value..!) Anyway, in case anyone else has the same problem the solution I found was to make sure that you've got the Navionics chart option selected, rather than the SonarChart option. The selection is via a little button on the display that I'd never used. It is just above the button for selecting head-up, course-up etc. For some reason SonarChart option doesn't display depths. I didn't even realise I had that option or that I'd selected it.
  8. #8
    Join Date
    Mar 2004
    Posts
    5,991
    Make sure it’s all still on the same WiFi address, if you use a phone hotspot or similar it may be logged into the wrong address.
  9. #9
    Join Date
    Jun 2016
    Posts
    171
    One of the options is to choose between original chart depths, or the user-provided sonar-chart depths. The detailed depths come &go as you toggle this on & off. Could that be it?
  10. #10
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    5,486
    Is there a printed manual (or a .pdf) available for the Navionics app? I seem to be learning how to use it by trial and error but I would like to sit down and read some proper instructions.
    "Brexit: like watching a library being burned down by people who can't read"
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
