Page 4 of 17 FirstFirst 12345678914 ... LastLast
Results 31 to 40 of 166
  1. #31
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,227
    Default Re: An infuriating national obsession- radio checks
    I do a radio check at the start of the season but do it with my marina or yachtclub bridge. have never done one with the CG
    When I did my VHF course the instructor certainly did tell us to do checks with the coastguard
    in my round UK trip a few years ago I do recall one CG station regularly announcing, after the weather transmission, that it was no longer responding to requests for radio checks (might have been only on 16 cannot recall)
    However, inspite of that, one would still hear a request for a check a few minutes later
    It is all down to the fact that my wife does not understand me !!
  2. #32
    Join Date
    Sep 2016
    London / Suffolk
    Posts
    788
    Quote Originally Posted by MM5AHO View Post
    I have yet to hear the coastguard reply that the signal was inaudible.
    Some people must use their radio very little. This year I've heard several calls to Oban Coastguard, and to Clyde Coastguard. Both haven't existed for long enough.
    But on another tack...
    I have several times heard the CG announcing that someone has a "open mic", and could they please check their sets. The problem of continuous carrier where someone sits on their mic PTT, or leans on it or something, effectively blocking Ch16 is real.
    But transmitting over the top of it asking them to stop it is a bit futile. The one who is sure not to hear is the one at fault, as their receiver is deactivated while they are transmitting. But how should they cure this problem? What can be done?
    On Sunday it was the CG that left their mic open!
  3. #33
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    19,429
    Quote Originally Posted by Barnac1e View Post
    It was certainly NOT recommended in my excellent DSC course at Parkstone YC, Poole, a few years ago.
    Nor in the northern Adriatic (Italy, Slovenia and Croatia). I have never heard a single one - even with no Slovene or Croatian I think I would recognise such a call - in the 35 years I have been sailing there.
    I use my fixed VHF to liaise regularly with friends when sailing in company, as we often do and with hand-held VHFs so cheap these days it makes sense to have a backup. And it is invaluable used for calling someone on board while away from the boat; that way both can be checked.
    My experience in the Adriatic is the same. We use our VHF at least once every cruise making arrival calls to a marina. Surely that's enough checking?
    Richard
  4. #34
    Join Date
    Nov 2009
    Posts
    19,429
    Does this thread represent a very good reason for using a splitter so your AIS unit is connected to the masthead antenna?
    Every time you turn on the AIS and see a target, at least you know that your connections etc are all hunky dory.
    (ignoring the frequency/impedance blah blah)
    Richard
  5. #35
    Join Date
    May 2007
    Cambridge, UK
    Posts
    6,042
    On my VHF course, the instructor labelled the radio check as the most widely misused call, and strongly discouraged us from using it UNLESS there had been a recent change to the system OR you had other reason to believe there was a problem (e.g. not receiving calls from nearby sources). He also stated loud and clear that the CG weren't the best people to do a radio check as a) they have vastly superior antennae and receivers to those we use, and can detect a signal that is unusable for others and b) they use a network of antennae, and the nearest one to you may be too close to provide a reasonable check. He suggested making an arrangement with another yacht, or using the marina.
    Commercial craft operate in a different regime and (above some size) are REQUIRED to do a radio check prior to sailing.
  6. #36
    Join Date
    Dec 2007
    Boat: Falmouth. Work: Cambridge
    Posts
    1,362
    By coincidence the CA issued this note this morning. It arose from one of their frequent meetings with the MCA (who are much too polite to say so but do not find 'radio check please' calls entirely welcome at busy times).
    CA House London:
    The Cruising Association's RATS (Regulations and Technical Services) Committee has been in discussion with the Maritime and Coastguard Agency (MCA) about the use of calls to HMCG on Channel 16 requesting radio checks.
    RATS has anecdotal evidence of a proliferation of such requests and that these seemed to have spread from the Solent to other areas and Falmouth in particular.
    Speaking on behalf of RATS, Robin Baron said, "It seems to us that this is not best use of HMCG resources at a time when we know that they are hard pressed with other more important issues including particularly Search and Rescue."
    Robin continues, "The MCA have confirmed that radio checks should primarily be conducted with local marinas and nearby vessels. Radio checks with HMCG should not be a first resort as it ties up the air and increases operator workload."
    RATS' own research has confirmed that radio checks with other vessels or shore stations at 1W power and at a distance of around 8 miles provide a much better test of antenna and radio set performance.
    Their recommendation is that radio checks should be carried out primarily with marinas and other shore stations or with other vessels. National Coastwatch Institute (NCI) shore stations are usually well placed for such calls which should be made on Channel 65.
  7. #37
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    14,162
    Quote Originally Posted by AntarcticPilot View Post
    Well said.
    Please make sure that the marina or other boat is some distance from you.
  8. #38
    Join Date
    Jan 2003
    Clyde
    Posts
    7,336
    Quote Originally Posted by westhinder View Post
    I can testify it is an English (South coast?) obsession.
    I have just returned from a 7-week trip to Galicia and back and the only radio checks we heard were when we were in range of the U.K. Coastguard.
    Not in Spain, not in France, not in Belgium or the Netherlands.
    I am utterly surprised the coastguard keep responding politely.
    To me it is like calling the fire service to check your phone works. Wonder what the reaction would be.
    It's not it's the same on the Clyde but perhaps they are from the south coast A lot of the time it's the same people over and over again. Comparing it to calling the fire service to make sure your phone is working is a very good analogy.
  9. #39
    Join Date
    Feb 2010
    UK
    Posts
    1,480
    Before setting off we always carry out a radio check on a yacht that we are delivering...
    International Yacht Delivery.
    http://www.halcyonyachts.com/
  10. #40
    Join Date
    May 2001
    Norfolk/Suffolk
    Posts
    2,980
    On a Simrad RD68, a poor tx signal will produce a “ant” icon on the screen indicating a possible weak transmission caused by an possible antenna problem, as mine currently is, accompanied by poor AIS tx, previously mentioned as another indicator of poor tx.
    Harwich for the Continent - Brexit For the Incontinent . Sadler 290
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
