Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Jan 2003
    Nazare Portugal
    Posts
    14,911
    Default H T electric cable clearance
    How close would you sail.
    Air Draft 17.5m thinking of going to Aveiro but HT cables shown as 22m in Reeds.
    Would you pass 4.5m from cables?
    Assume 22m is HAT!
  2. #2
    Join Date
    Jun 2004
    Fareham
    Posts
    6,461
    Default Re: H T electric cable clearance
    Surely that should be safe height in the worst conditions so MHWS or HAT with maximum cable sag and maximum arcing distance.
  3. #3
    Join Date
    Nov 2015
    Posts
    191
    I haven't a copy of Reed's with me at the moment, but I'm pretty sure the clearances are at HAT. There is a diagram in the front somewhere (even in the Channel copy, let alone the full one) showing clearances and rises of tide etc.
    I think I would sail with a 4.5m clearance from the cables myself, though I'm sure it would make me terribly jumpy in the same way that going under most bridges does—it never looks like you'll miss it on approach. Usual disclaimer applies, of course, but a routinely accepted breakdown field strength for dry air is about 3MV/m (i.e. 4.5m would breakdown around 13.5 million volts). Caveat is that this changes somewhat with humidity, but you'd be unlucky if they were even 800kV lines, so giving a field strength of about 180kV/m, which I would imagine is OK (though no electrical engineer). Of course, your mast is presumably terminated with a sharp-tipped conductor (aka VHF aerial), so this will worsen things a bit...
    If you have the depth to aim off to one side, you'll probably find more height (depending on the suspension arrangements) and obviously less rise of tide will also give a clearance boost.
  4. #4
    Join Date
    Jun 2013
    Hopefully somewhere warm
    Posts
    8,787
    Looks like some pretty tall masts on google streetview...
    https://www.google.co.uk/maps/@40.64...7i13312!8i6656
  5. #5
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    42,574
    Quote Originally Posted by Sailfree View Post
    Assume 22m is HAT!
    If you consult the Admiralty Symbols and Abbreviations , Chart 5011, you will find the meanings of the clearance figure printed on the charts are explained
    ITYWF that it is safe clearance above HAT ( highest astronomical tide) if printed in magenta but, like bridges, the actual clearance if printed in black.
    You will have to look in Reeds for an explanation of the figures they quote and treat with extreme caution
  6. #6
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    889
    Based in Nazare, you should be able to find people with local knowledge. If not, go at LW springs which will give another 2-3m clearance.
  7. #7
    Join Date
    Jun 2004
    Fareham
    Posts
    6,461
    Found and old copy of Reeds. They say that the Admiralty symbol - printed in Magenta with zig-zags either side of the number - means "Safe overhead clearance as defined by the responsible authority."
    Put your rubber boots on - you'll be fine!
  8. #8
    Join Date
    Aug 2013
    SW Scotland
    Posts
    18,479
    Assume 22m is HAT!
    I'm pretty sure that even 132kV insulators are a lot less than 4.5m long ...
    "Seamen are always wanting to do things the proper way; and I like to do them my way."
  9. #9
    Join Date
    Oct 2013
    Shropshire - Sundance, Bristol Channel
    Posts
    921
    https://www.google.com/url?sa=t&rct=...QLav7iSGPsCTA7
    The minimum extent of these zones varies according to the voltage of the line, as follows:
    low-voltage line 1 m;
    11 kV and 33 kV lines 3 m;
    132 kV line 6 m;
    275 kV and 400 kV lines 7 m;
    There's a pylon in our club Pill, 2 boats have gone under it and arced (sp) it's a total no go area, ram and grab onto another boat if needs be.
    I work on a 10m clearance for any power lines.
    Tom, Sundance
    2wheels1keel.com
  10. #10
    Join Date
    Mar 2015
    Isle of Eigg
    Posts
    6,668
    Quote Originally Posted by GHA View Post
    Annd... if you pan to the right you can see one of the pylons in question (I guess)
    If that is the ones then that is a very very very long span across a navigable basin, if theres 22m at the middle then theres going to be a bucket load more at the edges.
    Just call me Dougal, Sir Dougal to you.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
