Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Join Date
    Dec 2005
    Live London
    Posts
    3,435
    Default Re: detroit diesel ddec III
    I know nothing of these engines, however unless difficult I would suspect swapping the ECU over will at least validate that the ECU is working correctly post repair. Given it has been repaired etc this must be the first thing to check I would have thought.
    Multiple faults are of course possible, just less likely.
  2. #22
    Join Date
    Jan 2002
    Aberdeenshire, Scotland
    Posts
    4,349
    Quote Originally Posted by jrudge View Post
    Not quite sure if that will work jrudge .... and that may be one of OP's problems ... In twin installations one engine rotates to the Left (L) and the other rotates to the Right(R), and suspect that the ECU is configured specifically for the L or R rotating engine ... the serial number or the engine and gearbox will tell OP which is which and someone who know the DDEC ECU module may be able of telling OP if the ECU configuration differs from the L or R engine rotation... (Page 7 here ... https://avtec.edu/sites/default/files/DDC%2092.pdf )
    Regards, Alf
    I've stopped drinking water .... I have seen what it does to the bottom of our boat!
    "The only time you have too much fuel is when you're on fire."
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
