Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Nov 2018
    Posts
    2
    Default Sealing A Leaky Chain Plate
    I have a stainless steel chain plate for a detachable inner fore-stay for setting a storm jib. The chain-plate is through bolted to the bulkhead at the back of the anchor locker with six s/s bolts. Rather inconveniently if the anchor locker fills with water then water was getting through the bolt holes for the chain-plate into the fore-cabin. I have removed the chain-plate and re-bedded it with silicone sealant but have not yet tested it. However, I am also wondering whether the chain-plate could be painted with epoxy or some other material to optimise sealing.
    Does anyone have any thoughts or experience on this?
    Many thanks
  2. #2
    Join Date
    Nov 2007
    Posts
    32,180
    Default Re: Sealing A Leaky Chain Plate
    Have you really used silicone? - not really suitable for the job as it does not seal well to either wood or Stainless. Reseal it with either a polyurethane or butyl sealant - might also be a good idea to seal the holes in the bulkhead with epoxy first. The stainless does not need any coating - that is why stainless is used.
  3. #3
    Join Date
    May 2013
    Salcombe
    Posts
    13
    Reading a reputable American blogger a few days ago convinced me that silicone should never be allowed near a boat, though it's sold by most chandlers. I took out an aft cabin window last April; the previous owner had used silicone to seat the thing. The silicone had made a very poor, leaky sealing compound. So I scratched out the lot and replaced it with one of the Sikaflex compounds.
  4. #4
    Join Date
    Jan 2004
    Bricks & mortar: Italy. Boat: Aegean
    Posts
    10,252
    I can only agree that silicone is absolutely the wrong stuff (for most things) and that butyl or a polyurethane sealant would be far better. The trouble now is that nothing will stick to the surface coated with silicone without a fairly severe mechanical scrubbing. Fortunately, since it's stainless steel, that should be straightforward. The other surface to which the silicone was applied (GRP?) should also be thoroughly attacked in the same way.
    As well as bedding-down the body of the chainplate, if the bolts involved are countersunk, they're particularly easy to seal with butyl tape: simply form a butyl cone under each countersunk head and bolt down.
    All epigrams are false
  5. #5
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    8,765
    Quote Originally Posted by macd View Post
    Would not butyl gradually extrude over time? Would it not be better to coat the hole & thread in a Sycaflex?
    It is all down to the fact that my wife does not understand me !!
  6. #6
    Join Date
    Jan 2004
    Posts
    10,252
    Quote Originally Posted by Daydream believer View Post
    It does slowly extrude, but never in my experience to the point where the seal is broken. Excellent stuff, and never sets, so the items sealed can always easily be dismantled.
    Sycaflex is presumably the new green version of the well-known family of goo?
  7. #7
    Join Date
    Nov 2018
    Posts
    2
    Very helpful replies. Thanks guys.
    I previously thought that Sikaflex was synonymous with silicon - now I know better - my only problem is now I am not sure whether I in fact used used silicon or Sikaflex - hopefully the remains of the tube are in the locker.
  8. #8
    Join Date
    Jul 2009
    South Wales and Bristol Channel, UK
    Posts
    2,407
    Clean the surfaces with Acetone and then use polyurethane sealant; it won't leak!!
  9. #9
    Join Date
    Jan 2004
    Posts
    10,252
    Quote Originally Posted by Ghoster View Post
    Whatever it was, it clearly didn't work and will need to be removed. However, unlike silicone, a small residue of any Sikalex probably won't prevent the adhesion of any new sealant applied.
    Incidentally there's no more a substance called "Sikaflex" than there is one called "Heinz". It's a family of products with different chemistries and properties. If you use it, choose the right one for the job.
  10. #10
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,202
    Not quite the same job but may give you some idea of the steps necessary. http://coxeng.co.uk/sails-and-rig/sa...p-chainplates/
    Answers to some technical queries at new website http://coxeng.co.uk
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
