Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Join Date
    May 2005
    Loch Snizort, Isle of Skye
    Posts
    4,804
    Default Re: Sealing A Leaky Chain Plate
    Quote Originally Posted by vyv_cox View Post
    Not quite the same job but may give you some idea of the steps necessary. http://coxeng.co.uk/sails-and-rig/sa...p-chainplates/
    Very thorough and useful as always.
    I hadn't heard of Puraflex before. I've currently got most of my deck fittings off and will be re-bedding them, so am toying with various options such as CT1, butyl tape, or Sika.
    My chainplates have only a small tufnol covering plate held down by self tappers, rather than a welded flange at deck level. So I am leaning towards CT1 as being the most bomb-proof option. Any shrinkage away from the stainless chainplate itself will cause a leak though, so maybe it would be better to use butyl and just check/renew regularly?
    Deb 33- Wayfarer- Wanderer
  2. #12
    Join Date
    Oct 2002
    Plymouth
    Posts
    8,282
    Quote Originally Posted by Kelpie View Post
    Very ..... I've currently got most of my deck fittings off and will be re-bedding them, so am toying with various options such as CT1, butyl tape, or Sika.
    I have tried butyl tape but am not totally convinced yet. Polywotsits I don,t fancy at all. Tom Cunliffe has similar chainplates to you and was singing the praises of this stuff:
    https://www.sealantsdirect.co.uk/arb...rey-380ml.html
    I will be trying it next time.
  3. #13
    Join Date
    May 2018
    Posts
    569
    I swear by CT1, it's never let me down so far.
  4. #14
    Join Date
    Nov 2007
    Posts
    32,180
    Quote Originally Posted by doug748 View Post
    Same sealant as the tape you used but in a different form. Equally good at sealing. big advantage over polyurethane is that it is non setting. Another alternative is polysulphide (also non setting) from the same manufacturer. Had better be good as I bedded my keel with it in 1995 - still no leaks!
  5. #15
    Join Date
    May 2007
    Posts
    35,837
    In my view, the design of the joint and sealant interface is more important than the choice of sealant.
    Whatever sealant you use, there will eventually be problems if it's squeezed down to zero thickness by the pressure on the joint.
    You want something like a chamfer on the holes to provide some volume for the sealant.
    So you have something like 2mm of sealant where it has to move with the parts. Silicone for example will stretch something like 100% before failure, 2mm of it will survive the joint being stressed, a micron-thin layer will only move a micron before failure.
    Done properly silicone is a pretty good sealant. Others are better, but will still fail in a poor joint. Many have lower % strain to fail than silicone. Non-setting can move infinitely, but that's no good if it moves away from sealing the right bits....
    I'd use polyurethane because it is easy to to a good job of priming and porous surfaces, using normal paint primer or even varnish.
    With a chain plate, you need to be clear whether the bolts are supposed to be in shear or in tension, with the main load being friction between the plate and the substrate. A non-setting goo may allow all the tension to be lost....
  6. #16
    Join Date
    Oct 2002
    Plymouth
    Posts
    8,282
    Quote Originally Posted by Tranona View Post
    Quite so, the link tells us what it is. I am suggesting the OP might try Cunliffe's suggestion because it is a different formulation
  7. #17
    Join Date
    Feb 2007
    Essex
    Posts
    21,567
    My first thought, as a bodger rather than an engineer, was that the strength of the bulkhead at the join needs to be checked. If it is flexing or moving under strain, this might add to the problem and possibly some reinforcement at this point might assist.
    Far away is near at hand in images of elsewhere
  8. #18
    Join Date
    Jul 2009
    Winter in Falmouth, summer on board Rampage.
    Posts
    5,024
    If the problem is being caused by water sitting in th chain locker rather draining away before it has time to work through the seal, then perhaps improving the locker drainage arrangements might be a good idea?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
