Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,445
    Default Stainless sheet to ply glue
    Galley top - formica looks tatty and has not borne wear and tear too well. (Edit - the formica will be removed - in fact is in the process of self removal! Stainless sheet straight onto the ply).
    What is the best surface glue please?
    And Happy Christmas to all!
    I'd rather be naked
    www.mastaclimba.com
  2. #2
    Join Date
    Jan 2016
    Southwold & Ipswich
    Posts
    1,502
    Default Re: Stainless sheet to ply glue
    You're putting the stainless over the formica? If so scuff the formica and use SABA, Skia or similar combed over to give an even spread paying attention to the edges and corners.
    Did my oven surround like this with 1.2mm polished stainless and it went to flat as a flat thing.
    Electrical & heating engineer, Diesel remaps, Custom panels
    Southwold & Ipswich Yards
  3. #3
    Join Date
    Nov 2007
    Posts
    32,180
    Either a contact adhesive or a polyurethane as suggested above. Either will work but contact will cure quicker.
  4. #4
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,445
    Quote Originally Posted by matthewriches View Post
    Sika?
    I'd rather be naked
    www.mastaclimba.com
  5. #5
    Join Date
    Jan 2016
    Southwold & Ipswich
    Posts
    1,502
    Yes lol
    Quote Originally Posted by Graham_Wright View Post
    Sika?
  6. #6
    Join Date
    Nov 2001
    Me: Johannesburg South Africa Yacht: Richards Bay East Coast Africa
    Posts
    7,224
    Sika?
    I v'e used Sika to glue stainless steel chafe plates to my painted hull lots of times and they are still holding OK.
    Just roughen the back of the stainless with a rough file to gibe a better glue grip
    Life is too short not to have a sea view
    Distantshaws tinyurl.com/yclt6l68
  7. #7
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,523
    Quote Originally Posted by Rogershaw View Post
    If it worked Ok why did you have to do it lots of times
    Just asking !!
    It is all down to the fact that my wife does not understand me !!
  8. #8
    Join Date
    May 2018
    Posts
    769
    Gorilla Glue would do it.
  9. #9
    Join Date
    Nov 2001
    Posts
    7,224
    Quote Originally Posted by Daydream believer View Post
    Just asking !!
    Numurus different chafe plated.
    On one that was a section of tube around a slight curve did start to like at the ends so I just added a screw tapped into the gunnel to take the bend strain.
    All the ones on straight sections were file.
    When I said lots of times I meant lots of chafe plates.
  10. #10
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,523
    Why on earth does one need "lots of chafe plates" on a yacht?
    I can understand one at the bow for the anchor & one perhaps for the anchor cable on the deck. I have one where I rest the corner of the fuel can when I fill the tank, but apart from that I have all the lines arranged to stop any friction. ( As a control freak I have an option of 26 control lines to the cockpit) If lines rub then that is friction - is it not? I think that if I needed any, I might start by asking Why?
    Not a criticism- it is your boat after all, but it did get me wondering
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
