Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Join Date
    Mar 2007
    Atlantic
    Posts
    21,369
    Default Re: Electric winches / cordless drills
    Quote Originally Posted by Bouba View Post
    I used a Winchrite
    I like the look of that. Think its gonna go on my shopping list!
  2. #22
    Join Date
    Feb 2014
    The Northern Powerhouse
    Posts
    2,994
    This one looks good from Hitachi. The highest torque rating I have seen and more than a Winchrite. Half the price and with a spare battery as well, each battery having double the Winchrite capacity.
    A bonus is you can use it as a drill driver too. Get an angle grinder, impact driver and jig saw etc and you don’t need more batteries. It is a better spec than the one I have. Makita are a proper pro tool. I don’t know how well the Hitachi is made though.
    https://www.ffx.co.uk/tools/product/...mbi-Driver-Kit
  3. #23
    Join Date
    Mar 2007
    Atlantic
    Posts
    21,369
    Im more interested in the Winchrite as its designed for afloat use. Ive endexed a drill before with seawater. Open mind though.
  4. #24
    Join Date
    Feb 2014
    Posts
    2,994
    Quote Originally Posted by capnsensible View Post
    If you are going to get it very salty then it won’t end well. A protective coating like AC50 or Boeshield would be a good idea I think.The Winchrite isn’t waterproof by the way, just water resistant.
  5. #25
    Join Date
    Nov 2010
    Cambridgeshire, Spain, yacht Greece
    Posts
    93
    My Milwaukee has a protective neoprene sleeve which covers about 80% of the drill. It's made from wetsuit material which protects both drill and boat from damage and scratches. So far, in the two years I've had it, there are no visible signs of deterioration despite being in use during the 5 or so months per year we use the boat, admittedly in the Med. On present form, short of dropping it in the water, I think a drill will last quite long enough.
  6. #26
    Join Date
    Mar 2003
    s e wales
    Posts
    17,673
    Quote Originally Posted by Zing View Post
    A home made extra long winch handle might be all that is needed if it’s only the last bit of trimming that you find hard. You can buy slightly longer winch handles. Maybe you need to try them first if you haven’t already. Then again if it’s not a problem of strength, but stamina a drill will help.
    Its not really a strngth issue so much as an "out of puff" issue. The boat is 35ft, the genoa is 140% and the winches are 44s. Not that difficult to raise the main - more an issue of winding in the genoa if single handing. My pilot ( below deck hydraulic) is good but not sensitive enough to hold the boat just luffing the headsail to lighten the load.
    Not at all sure about having a heavy old lump of an electric drill in the cockpit all the time. And swapping from side to side.
    this post is a personal opinion, and you should not base your actions on it.
  7. #27
    Join Date
    Nov 2010
    Posts
    93
    Quote Originally Posted by birdseye View Post
    That's exactly my problem too, including the head to wind problem with hydraulic steering. However the drill cured that and I can wind in the foresail much more quickly than by hand. I don't think you will find the weight so much of a problem; at least neither my wife nor I do. Make up a 8.5kg weight with bags of sugar or something and try it out in the cockpit. I think you might me pleasantly surprised, particularly of you have enough strength for your genoa winches.
  8. #28
    Join Date
    Jul 2005
    Posts
    76
    I have used the Milwaukee 28 V right angle drill for years it is bullet-proof built to a very high standard you can charge batteries on board has more tourque than anything else on the market I winch my wife or myself up the mast no problem I even use it on my anchor windless if you want to use the two speeds i.e. forward and reverse just have a pinput through the Kranchor and shaft
  9. #29
    Join Date
    May 2003
    Eastern Atlantic seaboard
    Posts
    3,206
    A question for Winchrite owners. Do you believe this device will get an 80kg bloke (most of the way) up an 16m mast? Seems an easier option than self climbing gear with the bonus of additional applications.
    I'd rather be tethered to a pad eye than tethered to an iPad.
  10. #30
    Join Date
    Oct 2010
    Posts
    1,470
    Quote Originally Posted by SAPurdie View Post
    Also not why halve the cost by fitting only one electric winch as opposed to two? If you don't need room to hand wind it, it could perhaps be placed centrally somewhere like an old fashioned capstan, thereby covering all winching requirements?
    Maybe even put up with the reduced performance of a club footed self-tacker for short tacking?
    Buy a Dehler CWS. Ropes all come to one central electric winch. I love mine.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
