Page 6 of 6 FirstFirst ... 23456
Results 51 to 58 of 58
  1. #51
    Join Date
    Jul 2017
    Posts
    40
    Default Re: Electromagnetic log transducer.
    Would it be easy to wire into the Raymarine ST60 instruments, or SL70C chart plotter?
    My main interest would be in the true wind calculations that I think are based on the log speed. Does anyone know whether that works on nmea log speed or if it's just a seatalk thing?
    Thanks.
  2. #52
    Join Date
    Jun 2001
    Oban
    Posts
    789
    Quote Originally Posted by adamlang View Post
    Thanks.
    To get true wind on the ST60 wind display then boat speed is needed on Seatalk.
    I think the most useful way to achieve that would be to convert the NMEA output to log-type pulses and feed those into the ST60 log display, as discussed here. One snag is that uses the GPS speed sentence RMC but NASA outputs VHW. As Nigel Mercier showed, it's possible to "roll your own" so it shouldn't be hard to make a converter using VHW from a NASA log. I was thinking of doing that myself if there's positive feedback for the NASA log.
    Derek
  3. #53
    Join Date
    Aug 2010
    Bristol
    Posts
    959
    All hull mounted logs will be affected by weed and barnacle build up on adjacent hull and on unit itself, so none will be much good for navigation over any distance unless continually recalibrated. I adjust gain several times a year by comparing gps with log in still non tidal harbours or lagoons. The only advantage of the new one is that it cant be fouled by twigs or seaweed or broken by boat lifts. If I needed a new one it might be worth extra cost if it could interface directly with my TackTick but I don't and it cant.
    A boat is for going places
  4. #54
    Join Date
    Jan 2006
    Western Isles
    Posts
    22
    Thanks.
    My Raymarine autopilot has an NMEA input and outputs Seatalk, which your ST60 wind instrument could use. Perhaps your SL70 can do the same?
  5. #55
    Join Date
    Jan 2006
    Western Isles
    Posts
    22
    Well it's arrived. Nasa seem to have upped the quality of their packaging.
  6. #56
    photodog is offline Lord High Commander of Upper Broughton and Gunthorpe
    Join Date
    Apr 2007
    Posts
    35,482
    Quote Originally Posted by tean View Post
    So, how has this worked out??
    Keen to see a review!
  7. #57
    Join Date
    Jan 2006
    Western Isles
    Posts
    22
    Unfortunately I haven't had time to dry the boat out and fit it yet. I currently have an Echopilot paddle wheel job and need to enlarge the hole to take the new transducer. Might get it done next month.
  8. #58
    Join Date
    Jul 2015
    Posts
    1,722
    I too look forward to the report in due course.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
