Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Feb 2011
    Sussex
    Posts
    343
    Default Making gusset to fit curve
    Is there a technique for copying the curve of the hull onto a template, to make gussets to fit in the keel 'vee' of the hull?
    I watched a video of a spile & flag, but being in a vee, the other side would get in the way?
    This kind of thing
  2. #2
    Join Date
    Apr 2002
    Faversham
    Posts
    842
    Default Re: Making gusset to fit curve
    Make a rough template of stout card or thin ply. Then use a spacer and pencil to trace the shape. Lay the template on your gusset/floor material and use the same spacer, other way round, to trace the true outline on the material.
  3. #3
    Join Date
    Feb 2011
    Sussex
    Posts
    343
    Thanks.
  4. #4
    Join Date
    Jun 2017
    Posts
    728
    Quote Originally Posted by gdallas View Post
    Yes, and a circular spacer e.g. a rubber tap washer or something like that makes it easy to roll the pencil around at a fixed radius from the surface.
  5. #5
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    11,956
    I would start with a sheet of A4, push it down to the bottom then crease the paper round the curve, tearing the paper where necessary.
    Cut the paper round the crease, refit and add / remove paper where necessary. Transfer that shape to card (cereal packet) then refit to test.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  6. #6
    Join Date
    Jun 2015
    Posts
    1,439
    Three words. Ticking stick. YouTube.
  7. #7
    Join Date
    Jun 2007
    Benfleet Essex
    Posts
    1,092
    As above, Tick stick, otherwise known by boat builders as spiling. No poncing around with cardboard just a dead quick & simple method that works & is highly accurate.
  8. #8
    Join Date
    Nov 2015
    Posts
    944
    I have always used a drawing compass, but this seems a better way to do this type of thing.
  9. #9
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    4,442
    " Brexit is like watching a library being burned down by people who can't read"
  10. #10
    Join Date
    May 2007
    Posts
    36,231
    Quote Originally Posted by penberth3 View Post
    I find a thin spile kept vertical easier in the long run, as the offsets are in a fixed direction.
    A circle rolling on a surface traces a different shape, sometimes in a non-obvious way.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
