Page 10 of 16 FirstFirst ... 56789101112131415 ... LastLast
Results 91 to 100 of 159
  1. #91
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,830
    Default Re: Fitting Charge Pressure Guage kit to KAD42
    Quote Originally Posted by BruceK View Post
    Yayyyy my Molex connectors arrived. Bgr the connector doesn't include any crimp pins The race is still on.
    You might win the battle....but I’ll win the war
  2. #92
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,830
    Success!
    Worked like a charm. Stayed on all the time. The only annoying bit is when you throttle down to idle it will alarm. You only have to press the button on the side to stop it so not the end of the world.
    The boost at 3100 revs sat at 1 bar for the engine with a new turbo and 0.7 bar for the engine with a rebuilt turbo.
    Another thing to worry about!
    Sensor Temperatures both sat at 45c
  3. #93
    Join Date
    Jun 2006
    Posts
    1,145
    Good work!
    The pressure difference between the two turbos might just be inaccuracies in the sensors. Have you tried awapping the sensors over to see if the boost values change?
  4. #94
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,830
    No but great idea and easy to do!
  5. #95
    Join Date
    Oct 2014
    Ireland
    Posts
    79
    Nice work - time to order!
    Did you see a performance difference between engines in any way before before the guages said so?
  6. #96
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,830
    Quote Originally Posted by bowler View Post
    Not really to be honest
  7. #97
    Join Date
    Oct 2014
    Ireland
    Posts
    79
    Be interesting to see what happens when you swap them. A great idea regardless.
  8. #98
    Join Date
    Feb 2015
    Conwy
    Posts
    3,623
    Something doesn't gel with me. In the book of words is states the following figures:
    RPM KPA Bar
    1800 115 1.1
    2500 145 1.45
    3800 175 1.75
  9. #99
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,830
    Atmosphere temp difference? There’s a conversion graph somewhere. The engine bay temp was 44c ish at a guess as that’s what the sensor temp reading was.
    I’m sure they are not as acurrate as your proper gauges will be.
  10. #100
    Join Date
    Jun 2011
    Volos-Athens
    Posts
    4,663
    Quote Originally Posted by FARSCO View Post
    I forgot to ask about that as well when I saw your pic FARSCO, but I don't know volvos and I already suggested checking oil pressure on a manual Volvo box yesterday so don't want to make more silly suggestions
    FWIW (not much) my IVECOs on boost are stuck at 2bar (for a petrolhead that's an impressive value and the main reason for fitting boost gauges tbh...) the 1bar looks little.
    Now, if at 1800rpm you see .5bar and at 3800rpm you see .8-0.9 then the atmo pressure thing may be right. If not, there's something else to search, although tbh these gauges are mainly tools to check discrepancies and issue early warnings that something's not right, nothing more imho.
    cheers
    V.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
