Page 16 of 16 FirstFirst ... 6111213141516
Results 151 to 159 of 159
  1. #151
    Join Date
    Oct 2003
    west yorkshire
    Posts
    3,632
    Default Re: Fitting Charge Pressure Guage kit to KAD42
    pretty sure it will respond fast enough. The specific heat capacity of water is about 4 times greater than rubber. So if the cooling water is heating up, the rubber will heat up just as fast. The rubber is @ 3mm thick so the surface temp will be slightly less than the internal temp. However if I wrap the sensor onto the rubber hose with amalgamating tape, the sensor is effectively submerged into the rubber hose, and not exposed to the ambient air cooling it down. Should be good enough and plenty fast enough to indicate a developing issue. And I still have the over temp sensor/alarm indicators and I know they work. (2 new impellers please!)
  2. #152
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,910
    Quote Originally Posted by kashurst View Post
    Makes sense and no new holes
    Roll on the real test
  3. #153
    Join Date
    Jun 2006
    Posts
    1,176
    Well the spare bolt hole in the d4 inlet manifold is not m18, don't know exactly what size it is but it could be 10mm. 12mm or 14mm.
    So I couldn't fit the wireless pressure gauge. Oh well back to the drawing board.
  4. #154
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,910
    You can get the 1/8 npt adapters in any M size you need.
    Or get a M20 to M whatever adapter.
    What size socket goes on the current blanking bolt? Although not always....I have often figured out the bolt size based on which socket went on it.
    I owe you a beer!
  5. #155
    Join Date
    Jun 2006
    Posts
    1,176
    It was an Allen key head, either 6 or 8mm. I'm going to take the bolt out again and measure it, but I'm guessing it was m10.
  6. #156
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,910
    1/8" NPT Female To M10x1.0 Male Reducer Oil Pressure Gauge Adapter Black https://rover.ebay.com/rover/0/0/0?m...2F382268879272
  7. #157
    Join Date
    Jun 2011
    Volos-Athens
    Posts
    4,720
    Quote Originally Posted by FARSCO View Post
    note M10X1.0 is NOT the standard M10 bolt, X1.0 is narrower pitch.
    Having said that all oil/air threads I have on my IVECOs are M10X1.0...
    V.
  8. #158
    Join Date
    Jun 2006
    Posts
    1,176
    Right I've measured it and I'm reasonably sure it's M12, but what I can't be sure of is the pitch, so I'm going for it being a standard coarse pitch (1,75)
  9. #159
    Join Date
    Apr 2008
    Isle of Man
    Posts
    1,910
    It’ll be fine pitch now
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
